Old 06-19-2010, 02:11 PM
dmorton is on a distinguished road
vibration absorbtion and ballast
Ive read in a couple of places where a synthetic granite is used to make gantries and beds for cnc machines, because the weight and stiffness help reduce vibrations.
I find myself wondering if using oversize aluminum extrusions (such as the 80x80mm and 100x100mm types) and filling them with water would help with reducing vibrations.
Using a mix of water and soft plastic beads (pe, hdpe, pp) might result in a liquid with substantial vibration absorption capabilities.
The other idea is to include a hollow region in the base of my moving-bed gantry that can hold a water bladder. The elastic nature of the bladder would absorb vibrations well.
Been wondering about these things because i am trying to build a machine that is portable - it should be lightweight and easily disassembled.
CO2 power supply ballast resistor? pixpop Laser Engraving & Cutting Machines 3 12-20-2009 09:31 AM
"Ballast" Resistors - Pls Check my numbers!? JohnnyVegas General Electronics Discussion 10 08-07-2009 06:30 AM
Ballast Resistor Needed jimmy2020 Laser Engraving & Cutting Machines 4 10-19-2007 11:42 AM
Too much vibration with my X2. alexccmeister Benchtop Machines 11 06-04-2007 01:36 PM
Ballast Resistor & 24v Power supply arman Hobbycnc (Products) 0 04-10-2007 12:23 AM
