This seems like a pretty nice xy table, I think it came from an industrial sewing machine. The threads don't seem to be ACME, any guesses? It has about 10.5x10.5 of motion. I think the motors (not shown) are 450 oz unipolar steppers. I'm considering mounting it to replace the Y and Z axis on top of a Solsylva table with the the goal of routing dimensional lumber or making small parts out of plywood/mdf. My motivation is purely for hobby purposes. Suggestions welcome. |
| As best I can tell, it is 1 start. Regardless, I think I have a pretty solid plan for it.Embedded Acquisition Systems shows a nice example of mounting a wood router to a micromill z-axis. I'm planning to build an enclosure around it, swap the steppers with smaller Xylotex steppers then add the Harbor Freight z-axis and spindle. |
| I have scrounged my Y and Z axis off an old blueprint reducing machine so your hardware looks very doable. Have you checked the nuts for backlash? If they've done a few hundred miles on an industrial sewing machine they might be a tad worn. It would be a shame to build a machine around hese parts if they're worn. The parts that I obtained had been used extensively but with extremely light mechanical loads, just moving lenses and stuff and subsequently have little actual wear and very minimal backlash. |
| One of the nuts has something hanging out of it. Not sure if I should leave it alone or dig in to see what's going on. Probably the latter. I stuck a dial indicator on it and am trying to measure backlash by hand. No conclusions yet, other than it seems pretty smooth, I can make it go to any number I want on the thousandths of inch scale. I think I can simulate steps by making a mark on the timing gear then moving it forward a few ticks then back to its original position. |
| I would be willing to bet the screw is multi-start. It is hart to tell if you can't see the end of the screw. The nuts are probably anti-backlash. If the nut has a small spring wrapped around one end, that's what it is. John |
| CNC router table to cut mostly foam and some light wood. | rcbamm | DIY-CNC Router Table Machines | 17 | 10-24-2011 12:13 AM |
| MDF vs Plywood and wood vs metal Router table | bevins | Open Source CNC Machine Designs | 20 | 10-09-2010 01:20 PM |
| Anyone make a plasma/router table? | bamwa | CNC Plasma and Waterjet Machines | 14 | 01-13-2009 12:49 AM |
| Can a wood router make paint stencils? | samualt | DIY-CNC Router Table Machines | 2 | 05-10-2004 12:46 AM |
