Old 06-16-2010, 11:02 PM
woodchuck5 is on a distinguished road
C10 breakout board I/O questions
I am in the middle of a design/build process for a CNC router. This will be a 3axis machine and I'm getting the NEMA 34 640oz-in kit (including cnc4pc C10 breakout board) from Kelinginc.net and Mach3 software.
I've studied various media PDF/video manuals on both the C10 and Mach3, and have learned there are only 5 inputs available - 10, 11, 12, 13 and 15. Well - really just 4 because pin 10 is the E-stop.
I'd like to have both limit and home switches for all three axes. My thought was to wire one each of the x, y and z limit switches in series and connect them to say pin 11 then use 12, 13 and 15 to double as the other end limit as well as the home switch. I just got finished watching a video from Mach3 on setting up limits/home and it said you could use the same switch and home. Does this seem reasonable? Suggestions on how these inputs are typically configured?
Also, on the outputs - I understand a number of output functions can be setup and the C10 board puts 5 volts to a given pin for the programmed output when it is turned on. Could a person use a 3-32vdc solid state relay to serve as a slave relay to turn on a larger load such as an AC motor?
Thanks,
Brian
Wiring Breakout Board Questions Dingo745 Xylotex 14 03-31-2008 02:47 PM
Breakout board, Relays on board? Cooper Open Source Controller Boards 11 06-09-2007 07:55 PM
Best breakout board? nate Xylotex 1 01-03-2007 07:39 AM
Breakout Board, Gecko 5VDC questions mxtras Stepper Motors and Drives 18 03-23-2006 04:06 PM
Breakout Board Operations Questions SPEEDRE General Electronics Discussion 0 01-01-2006 05:26 PM
