Old 06-16-2010, 12:04 PM
louieatienza is on a distinguished road
Cutting Magnesium
OK.... I've done a bit of research on the subject and came up with the following:
1- easily machined, though lower feedrates should be used
2- should NOT use water for coolant; mineral oil is best
3- swarf is HIGHLY flammable
4- dry sand should be kept nearby in case of fire
Is there any other percautions? Also:
1- What's the best way to dispose of swarf (especially if it's contaminated with mineral oil?)
2- Is using dust collection safe (i.e. static charge igniting swarf/dust?)
Thanks in advance, Louie
Old 06-16-2010, 09:25 PM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
run it dry
A poet knows no boundary yet he is bound to the boundaries of ones own mind !! http://cnctoybox.org
Old 06-17-2010, 08:49 PM
johnmac's Avatar
johnmac is on a distinguished road
I work with 1/4" sheet magnesium at work. It cuts on a band saw good, using a wood cutting blade with a rather low TPI count and wood cutting FPM. I use a router table with a HSS bit to bevel the edges, and a Rotozip with flex shaft and HSS bit for hand carving. Carbide will work, but is not a requirement.
Chips, shavings and dust can be dangerous. The finer the dust, the easier it is to ignite. Any other dust mixed in, like saw dust or even floor dust makes it even easier to ignite.
Once lit, it produces light so bright it will burn the retina in your eyes, like looking at arc welding.
Once lit, magnesium burns so hot that if water is sprayed on it, rather than putting the fire out, the heat will break the water down and separate the Hydrogen and Oxygen atoms which in turn feeds the fire.
When magnesium burns, it gives off long soot streamers, like a cutting torch with the Oxygen turned off. Don't breath it!
I keep a bucket full of plastic bags of sand. Should I ever need them I would toss the bags on the fire, bag and all. Remember it burns hot. You may not be able to get close enough to dump the sand on the fire.
A shop vac makes a good dust collector. Everywhere the dust can contact is plastic and spark proof.
The best safety tool of all is good housekeeping. The dust can't burn if it doesn't have a chance to build up.
Always clean all magnesium scrap and dust up, including any power tools used, before using them for anything else. This is especially true for any metal working tools.
John
Old 06-18-2010, 11:32 PM
Thanks for the replies... I also posted the question on the materials forum of the metalworking section. It's interesting that here in the DIY section, the response is more like "proceed woth caution" and in the metal section the response is skull-and-crossbones do-not-attempt!
As a former avid camper I'd keep one of those magnesium bars for making shavings to start fires, so I'm well aware of the risks. I'm kind of worried how and where to store and dispose of the waste (other than camping...)
Old 06-19-2010, 12:33 AM
CarveOne is on a distinguished road
Check with a local metals recycling center. Otherwise, the sawdust might be good for the tomato plants.
CarveOne
CarveOne
Resistance is not futile. It is voltage divided by current (R=V/I).
Aluminum or Magnesium ranchak Casting Metals 5 02-06-2009 02:47 AM
Magnesium coatings kz1670 Mass finishing equipment/media/stratigies 0 02-27-2008 07:44 PM
anyone have experience cutting magnesium??? superrat General Metalwork Discussion 32 12-15-2006 08:19 PM
magnesium metal and magnesium industry magnesium Product Announcements & Manufacturer News 0 09-18-2006 03:51 AM
Where to buy Magnesium? vadimvc General Metalwork Discussion 3 09-12-2006 11:21 PM
