I apologize again to put the post here because most people tend to look here alot. ok I got my HITACHI X200-022SFEF now I need to set it for my water cool 2.2kw 220V 7.5A 24000RPM spindle GDZ-10. Maybe steve wanna help me with this? |
| I don't remember seeing E05 (motor overload) when I did my install. My motor would spin very slowly. There were two settings that I needed to change: A003 and A004. This seems to be a sticky point for most Hitachi owners. Double check A061/A062 as well. http://cnczone.com/forums/showpost.p...&postcount=147 Steve |
| ok last night I reset according to this: A001 - 00 A002 - 02 A003 - 400 A004 - 400 A082 - 220 b012 - 7.5 H003 - 2.2 H004 - 2 and it is running for 20 hours now without tripping. Steve do you hook the x200 to your pc? I'm planning to hook it up to pc but hasn't got a clue of which breakout box and settings. Thank you Steve. |
| No, my spindle is not doing anything fancy with the PC. I do have it under on/off control via a relay from my break out board, but that's it. No speed control at this point because the knob on the front of the VFD handles that pretty well. Steve |
| got it working..
__________________ Is a sentance fragment? |
Here are my settings: A001: 01 (terminal input speed control) A002: 01 (run command from terminal input) A003: 130Hz A004: 400Hz A082: 230VAC H004: # of poles for your spindle F001: 400Hz My 0-10V leads from the BOB are fed into the "O" and "L" terminals. Hope this helps. |
| I have the 2.2KW watercooled spindle.. how many poles do i have! It never stated.. or came with any documentation. programming mine now. MRM the quoted commands below for A001 and A002 are if you want to use a breakoutboard to control the spindle speed right? If you want manual, then use 00 and 02 right?
#10
A001 = 00 A002 = 02 |
#11
| Updated Settings! got it to work!! ![]() X200 hitachi VFD with 2.2KW spindle. X200 settings: A001: 00 A002: 02 A003: 400Hz A004: 400Hz A061 400 A062 200 A082: 230V A151 200 A152 400 A153 0 A154 100 A155 00 B012: 10 H003: 2.2KW H004: 2 poles Last edited by diyengineer; 12-14-2010 at 02:11 AM. |
#12
YouTube - Cnc Rebuild Video #35Edit** she screams now! :P Wooo hooo! Damn A003 Base Frequency was set incorrectly. I thought "base" sounded like Minimum but NOPE. set it to 400HZ and you will be on your way! Last edited by diyengineer; 12-14-2010 at 01:34 AM. |
| DSP settings | rocabig | Excitech routers | 5 | 12-04-2009 03:46 AM |
| Hitachi X200? | fritts | Phase Converters and VFD | 2 | 12-26-2008 09:06 PM |
| Need Help!- Mach3 CV settings vs. G-100 Plugin CV settings | Bfarn | Machines running Mach Software | 7 | 12-17-2008 10:45 AM |
| LOOKING FOR SETTINGS | curlyweld | CNC Plasma and Waterjet Machines | 2 | 03-20-2008 01:14 PM |
| dnc settings | jamesr | Fanuc | 1 | 02-02-2006 02:13 PM |
