Old 06-04-2010, 10:28 PM
mark_detroy is on a distinguished road
cloumbo spindles
do most of the high end spindles use cermaic bearings?
i under stand these units require a warm up and cool down period
during start up of spindle... are the bearsing a bit scratch sounding till they warm up i herd one once.... bearing noise was little louder and dry( scratchy sound.....
please post comments
ger?
Old 06-05-2010, 11:28 AM
ger21's Avatar
I used HSD spindles with ceramic bearings for about 10 years, and they never made any audible bearing noise. We also never warmed them up, as they never told us we needed to when we bought the machine 12 years ago. Not sure if warming up would have made much difference, because the powerful electric cooling fans would cool it down in minutes if it wasn't running.
That's all I can really tell you, as I have no experience with Columbo spindles.
Old 06-05-2010, 07:22 PM
this what i herd .... regarding warmin up spindles regardingthe ball bearing which are seal, the fan is not directly cool them...
WARM UP: Do not apply loads to a cold electric spindle.
Before commencing work, run the spindle at 9,000 rpm for
10 minutes or until the spindle bearing supports reach 98º
F (human body temperature). This allows bearings,
supports and shaft to reach their designed dimensions
through thermal expansion. Applying loads to a cold
spindle will cause premature bearing failure.
COOL DOWN: Allow cooling system (fan, compressed air
or liquid) and bearing pressurization (if fitted) to run for 10
minutes after stopping work. This minimizes condensation
and prevents contaminants from being drawn into the bearing
cavities.
Old 06-06-2010, 07:35 AM
wcarrothers1 is on a distinguished road
I have an ekstrom carlson spindle. It has been great and had it for several years now (admited light use in my home shop) but will admit some of what I could call bearing noise on speed up and slow down (probably between 50 and 200rpm ish) but no noise other wise. Typically I"ve let it run free for a min or 2 before cutting but again I would not say I really push it hard anyway. Some days I give it more "warm up" time and other times not.. I suspect the unit will last for my lifetime +...
I'd say most standard shops don't have 10 min to give a machine time to warm up..
not sure if my particular ekstrom C73 unit has ceramic or not.
b.
Old 06-06-2010, 03:55 PM
LazyMan is on a distinguished road
Not all quality brand names use ceramic bearings on there lower RPM spindles. From what I have seen though, with RPMS above 18000 they tend to use ceramic bearings.
I always let my cheap Chinese spindle warm up for 10 minutes. I think it would be insane to not do it (if you know that you are supposed to) especially when running spindles that cost $3500+. With proper planning, the warm up can be done while you are getting the shop prepared for a days work, or perhaps having a cup of coffee. If your machine is idle for a few hours you can do another warm up cycle.
Spindles wcarrothers1 DIY-CNC Router Table Machines 3 02-13-2009 10:46 AM
Air spindles sizmo Toolgrinding & Toolgrinding Machines 1 12-16-2007 08:06 PM
air/oil spindles Shizzlemah Fadal 2 06-08-2006 09:41 AM
Spindles swoolhead DIY-CNC Router Table Machines 7 10-05-2005 10:06 AM
