Old 06-03-2010, 04:43 AM
cbstephenson is on a distinguished road
CNC Router-20"x20"x4" Build or buy machine?
Hi there i am new to this website but already browsed through alot of info.
i am interested in building/buying a cnc router machine with about 20"x20"x4" travel, not important but around that size.
will be machining wood,plastic and maybe aluminium. I have serched on the net and there are alot of diy and kitset cnc but i am interested in some advise. Like everyone i would like to do it on the cheap.
Cheers, Craig
New Zealand
Old 06-03-2010, 10:56 AM
louieatienza is on a distinguished road
Cheers, Craig
New Zealand
Craig, the first thing to do is define "cheap!" The next thing is look at plans and kits and see what is available at your price point, and you may have to adjust your price or expectations... and abilities. Do you own or have access to tools, or must you rent shop time or farm out work?
Speaking of time - it doesn't get mentioned often, since a lot here do this out of hobby, passion, or both. One should also weigh the cost of time in planning, ordering, building, and tunung, versus a more expedient approach of buying a kit or ready-made platform. Even a kit takes a good deal of time for assembly and tuning.
Old 06-04-2010, 12:16 AM
crane550 is on a distinguished road
Check out my build- and note the dates. I would say I have put an easy grand into my machine and I am not even close to done yet. Just made her first cut tonight and I am months into it.
http://www.cnczone.com/forums/showthread.php?t=103069
Old 06-04-2010, 02:02 AM
crane550/louieatienza - thanks for the link to your build. looks like it is coming along well.
will look into more. i feel the physical build of the project will not be a problem as i am a fitter/turner/machinist with full access to a work shop but i may struggle with the computer/programing side of things as i have no real experience with that stuff? how hard is it to learn?
would consider maybe buying a complete unit ready to go if i could find something around that size for under 2000 USD. although saying that living in new zealand may be quite expensive to freight to?
Any links and advice would be most appreciated.
Cheers
craig
New Machine Build- One years worth of pics and videos of my 43" x 98" MDF machine FIRST BUILD!!! Grunblau DIY-CNC Router Table Machines 107 01-25-2012 09:58 AM
"low end" HF Spindle or "high end" router for about $1000? biomed_eng DIY-CNC Router Table Machines 14 01-06-2012 12:15 AM
New Free CNC Router Plans 12" X 11" x 4", Build for $220 or $105 Modular CNC Open Source CNC Machine Designs 0 11-08-2009 11:36 AM
24x24 "square" router build nicanor76 DIY-CNC Router Table Machines 6 05-29-2008 04:37 PM
First Router Build, Is The Frame "Beefy Enough" jimbooboo DIY-CNC Router Table Machines 2 04-06-2008 12:49 PM
