Hi Group I`m working on a spindle configuration for my DIY router. I`m hoping to use a spindle that was purchased on ebay to mill wood and metal. Its too early to tell if my machine is rigid enough to mill steel but that is one of my additional hopes. I`m planning to use a 3/4 hp permanent magnet motor to drive the spindle. The spindle will be driven by 3/4 wide, 3/8 pitch timing belts. My biggest design issue is will a 3/4 PM motor be large enough for all the materials I hope to mill including steel. The motor speed is 2500 rpms. I choose this over a 1725 to allow me to change pulleys to get the spindle up to 8000 -10000 rpms for the machining of wood. I`m hoping someone could provide some advice on this issue. Note: The motor is a Baldor CDP3443 with their variable speed controller. http://www.baldor.com/products/detai...%2E75&rpm=2500 |
| Well, a big consern is what the bearings can withstand for the spindle when choosing speeds. Over at surpluscenter, they have 2.5hp DC motors and controllers for a rather good price, and even better is that they are rated over 6000rpm. http://www.surpluscenter.com/item.as...783-A&catname= There is the same motor with a diff mount too, http://www.surpluscenter.com/item.as...tname=electric the controller I have, the controller JRoque uses: http://www.surpluscenter.com/item.as...tname=electric Before deciding on the speeds, figure out what the bearings can handle. What spindle taper and all does that have? Jon |
-Spindle Housing is made from Steel -Timing Belt Pulley Drive, #22L075MP Pulley -Comes with 5/8" 5C Collet and Endmill -Perfect for homemade lathe, mill, CNC projects -Bearings are 6209Z with a light preload on them -Bearing were press fit into housing and shaft was press fit into bearing ID's -Overall length is 9.5", the housing O.D. is 4.5", bottom flange is .38" x 4.75" x 7.25" -.56" diameter holes are centered on bottom flange at 2.5" & 5.75" -The tools or workpieces are tightened in the collet with a standard 5C tightener (green handle) but it can be modified to fit your app |
| CNC Controlled Spindle motor speed control | gregmary | General Electronics Discussion | 13 | 02-27-2009 07:01 PM |
| Wood router, suitable spindle drive like shopbot? | GalaticDan | Commercial CNC Wood Routers | 5 | 06-09-2005 11:32 AM |
| 2.2KW Allen Brad. Spindle motor? | GalaticDan | Servo Motors and Drives | 2 | 02-02-2005 11:46 AM |
| Sand/Bead Blaster wood cutting | DDM | DIY-CNC Router Table Machines | 13 | 12-27-2004 08:12 AM |
| Cutters for Wood Question | paulried | DIY-CNC Router Table Machines | 9 | 05-13-2003 01:05 PM |
