Old 05-31-2010, 05:47 AM
stk2008 is on a distinguished road
Im after endmills etc
Hi every one im looking for a good source of end mills etc.
Problem I have is im using a wood router and the smallest Collete is i think 6mm but I need to get a 1mm cutter end mill with a 6mm shank.
I have looked at some end mills etc but they all use a 3mm shank so I have no way of usin them.
If any one knows of a good source IN THE UK that would be great.
Price is important as like others im skint :P hehehe.
thanks all
Old 05-31-2010, 10:35 AM
M250cnc's Avatar
M250cnc is on a distinguished road
What you need is a reducing bush.
As you say you are skint then you will find it cheaper to source cutters of your desired size which probably have a 3mm dia shank.
Looking for endmills of 1mm with a 6mm shank will be the most expensive option
Phil
Old 05-31-2010, 01:15 PM
Hi thanks for the reply where could I get the reducing bushes from as I dont have a lathe to make my own
Old 05-31-2010, 02:28 PM
Smiler is on a distinguished road
Lightbulb
Try Trend
I have used these collet reducers and they have been very good
Jeff.
Old 05-31-2010, 03:13 PM
ohhh cheers i have bookmarked the site thanks.
damn its hard to get a nice variety of tooling when you are forced to use a wood router hehe.
Old 06-02-2010, 09:45 AM
Hi there well I have got one coming now thanks to all that helped.
Instead of starting a new thread (I hate to do that for one question)
Im after some kind of gearbox with er25 or so Collette built into it so I can attach a motor of my choice i did see one some where but cant remember where now.
basically its a box with a gearbox in it and on top a shaft to attach a pulley and under it an ER20 or so Collete
thanks again
Old 06-02-2010, 11:26 AM
M250cnc's Avatar
Hi i replied to thread earlier, and i came here to see if you had another problem.
The problem you now have is that someone who may know the answer to your new question may not answer as the title of the thread is misleading.
So the best way to get an answer to the gearbox question is to start a new thread with the correct title.
HTH
Phil
Old 06-02-2010, 11:33 AM
Hi there yes you are correct I will make a new thread thanks for your help now and your last comments on the reducing Collete.
thanks
endmills cm92 Benchtop Machines 25 05-25-2010 11:43 PM
Which Endmills?! firestorm1284 Benchtop Machines 7 02-26-2009 09:59 AM
What are these endmills worth? aaron p General Metalwork Discussion 2 02-08-2009 12:08 AM
Endmills in Canada??? mindstorm88 DIY-CNC Router Table Machines 0 07-28-2006 08:44 AM
Anyone used these endmills? Cold Fusion General Metal Working Machines 8 09-12-2004 11:16 PM
