Old 05-30-2010, 10:19 AM
pjl83 is on a distinguished road
Uk supplier of motors/bearings...... recommendations please?
I'm new to this forum. I've been thinking of building a cnc routing machine for a while now and after looking through the build threads here and watching numerous videos around the net I've decided to take the plunge.
I'm a keen woodworker and I think that a machine like this would be a fun build and if works well then it would be fun to use also. I can't afford to buy a kit straight away, I'll start by doing the design, the woodwork and mounting the bearings, rails, motors and the cutting tool. Once I have this sliding freely I will look for the drivers and software etc........
I am looking for a recommended supplier for the bearings and motors (3) to begin with, I can source the other stuff locally....
Any thoughts on what I should be looking for with regards to the motors? It will be constructed from MDF and aluminium angle and the bed will be around 12" x 24" and moved via threaded rod and nut runners.......
Any advice at this point would be gratefully received.
Paul
Old 05-31-2010, 04:04 AM
Kipper's Avatar
Kipper is on a distinguished road
Hi and welcome to the zone!
Here's a smattering of advice....forget the threaded rod...use rack and pinion.... £70 will provide 2M of rack and 4 pinions...adjust the axis sizes to suit.
Bearings.....you could go AC type or as you really don't need them skateboard bearings are a favourite.....Were they to mount the screws?
Motors/drivers I only consider Zapp for these....reasonable cost and an easy supplier to deal with.
Rack as mentioned by a member
Stepper driver kits.....check individual prices
Keep the MDF dry and lacquer/varnish or even paint it! if it all goes wrong let me know as I use MDF to keep my workshop warm
Linear bearings can be expensive! either find a design to use or design your own....or bite the bullet and purchase some "proper" bearings.
Jena Tec Use the phone and ask what's on special offer
You'll find Jena to be about a third to a quarter of the price of the ebay sellers....hopefully!
Keith
Old 06-05-2010, 09:57 AM
Thanks for that,
Jena are about 10 minutes from where I work so I'll pop in for a chat with them
Metabo Electric spindle, 16mm Japn linear bearings, stepper motors kreitzz EBAY ADS 0 03-03-2010 12:46 AM
Largish Stepper Motors & 0.5" Mounted Linear Bearings TheMobster Want To Buy...Need help! 2 06-18-2009 12:56 AM
Gecko recommendations and wiring for my motors jemmyell Gecko Drives 7 08-22-2008 05:56 PM
skate bearings versus linear bearings paul langwade Linear and Rotary Motion 7 05-29-2006 10:06 AM
the future? cnc without motors,screws or bearings jimbo DIY-CNC Router Table Machines 4 04-22-2004 12:25 AM
