Old 05-25-2010, 03:53 PM
Rene Nuņez Paz is on a distinguished road
Need help with small unipolar stepper motors
Hello, Iam building a cnc embroidery machine, work is detailed here
http://www.cnczone.com/forums/showthread.php?t=57404
I have three stepper motors, from Panasonic dot printers. I don't have information about volts, amps and electrical wires connections.
Steppers are
1-PJJQ113ZA-P Matsu****a line feed motor
36 Omhs Japān
Panasonic printer KXP1624.
7.5Deg/step
48 pasos/rev
2-PJJQ92ZB-P Line feed motor with brass gear
PANASONIC DOT PRINTER KX-P1124 line feed
Resistance (Ohms) 9.5
Wires 6
Steps / Revolution 48
Step Size (degrees) 7.5
Gear Diametrial pitch 50
3- PJJQ114ZA-K Kyushu Matsu****a electric Stepper with optical wheel & cog
Nominal Voltage 3.1
Resistance (Ohms) 3.4
Wires 6
Condition pulled
Steps / Revolution 200
Step Size (degrees) 1.8
I need to know if I can connect it in a CNC controller with a 33VDC power source.
I need to know amperes for these motors for set Vref in CNC controller.
I need to know about torque, to see if is enough for project.
Thanks in advance for any help than can give me.
Sorry my bad English
Regards
Rene
Looking for small cheap stepper motors abbtech Want To Buy...Need help! 0 10-26-2009 08:55 PM
Need Help!- small tuning problem with stepper motors springlakecnc Mach Mill 1 09-03-2009 06:30 PM
Connecting bipolar motors to a unipolar controller tommee10533 Controller & Computer Solutions 1 05-04-2009 10:30 AM
bipolar/unipolar motors studysession General CNC (Mill and Lathe) Control Software (NC) 2 02-17-2007 01:50 PM
Bipolar from unipolar motors MrWild Stepper Motors and Drives 5 05-13-2006 10:56 AM
