Old 05-25-2010, 12:49 PM
thatguy666 is on a distinguished road
8' x 4' x 2' CNC router
Hello,
I'm looking to build a cnc router large enough to cut a single piece of plywood. Currently I'm trying to build a support table on the cheap. The size would probably be around 9' x 5'. Is plywood or MDF dimensionally stable enough to use as a base for this table? I've also been looking into framing systems and steel tubing. Any suggestions. Thanks
Old 05-27-2010, 08:02 AM
jsheerin's Avatar
jsheerin is on a distinguished road
It depends on what you're trying to do with the table and potentially what tolerances you're trying to hold. However, if you seal it well or keep it in a temperature / humidity controlled room, it could be dimensionally stable enough. I used 2x4's for my table, but my router (built from 80/20) rests on top of it, so if the table moves a bit it's not the end of the world.
Need Help!- with a Precix Table Router with Perske router SignShop Grunt General CNC (Mill and Lathe) Control Software (NC) 7 09-08-2010 04:08 PM
Build Thread- Building a CNC Router; by someone who can't build a CNC Router Womble DIY-CNC Router Table Machines 2 09-27-2008 07:51 AM
Newbie- Does anyone own a EZ Router Machine? Plasma or Router. sngatlanta Commercial CNC Wood Routers 30 04-11-2008 10:48 AM
Using a router for the 1st time. Need advice of cut speeds, router bits etc. Apples DIY-CNC Router Table Machines 19 09-23-2006 03:33 PM
Surfcam PP for Isel router / Precix router IvanTochev Post Processor Files 2 05-12-2004 12:27 PM
