Old 05-23-2010, 11:18 AM
pablogm13 is on a distinguished road
Finelineautomation machine build
I always dig watching the new machine builds so I figured I'd share some of mine.
I've spent about 7 hours on it so far. Most of the time has been spent on the angled steel bar joining the legs. I did it so I could add some casters to the four outer legs. I'll still provide support for the center legs with a block when in use, but I wanted the added support when moving it around and I wanted them to help keep things square. Anyway, the most time consuming part was aligning the holes on the steel with the t-slots. Once I figured out how to work with the t-slotted material it was just tedious but not very hard work.
Tonight I'll start assembly on the rails, rack & pinion, and gantry. Still waiting on the electronics kit so I'll see how far I get it before I have to stop.
ID:	107717   Click image for larger version
ID:	107718   Click image for larger version
ID:	107719   Click image for larger version
ID:	107721   Click image for larger version
Old 05-23-2010, 11:45 AM
jalessi's Avatar
jalessi is on a distinguished road
Thumbs up
Pablogm13,
You may want to check out leveler (leveling) caster's.
http://tinyurl.com/2e5c7r5
Nice work so far,
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Old 05-23-2010, 12:16 PM
Thanks Jeff. I had seen those casters on another build but they are out of my price range. I already blew my budget by a few hundred bucks so I had to modify some standard casters to fit to the bottom of the assembly. Who knows, Maybe I'll upgrade to those some day... Specially if I find issues with this thing not being level or square.
Newbie- Want to build my first CNC machine :D Chris85 Benchtop Machines 4 10-16-2009 12:41 PM
Need A Quote- CNC Machine Build CyborgCNC Employment Opportunity 6 08-04-2009 03:28 PM
Need Help!- new machine build don_don Automation Technology Products 0 02-08-2009 11:39 AM
Build Thread- My first machine build Sendo DIY-CNC Router Table Machines 13 07-12-2008 06:42 AM
New machine build under way. EL34 DIY-CNC Router Table Machines 21 02-20-2008 06:41 AM
