Old 05-22-2010, 03:52 PM
Realmseeker is on a distinguished road
Y axis drifting
Good day all,
I have been trying out the CNC for the first time over the last few weeks. I Have it actually doing some of the basic wizards built into Mach3 just to get a feel for what I can do as I learn more Cad/Cam stuff. I tried the circle wizard just fine, but the Rectangle pocket ones and other shapes are causing me a few problems.
When I set it to cut a rectangular pocket, the y-axis drifts negative after each successive plunge. As you can see in the pic, it looks like a bunch of steps. The X and Z seem to be doing fine. The good news is that the bottom edge to the far edge measures the correct width.
I tried playing with all the CV settings. Tried changing the pulse and steps up to 4(maybe try 5?), up the frequency from 25k, to 35 and 45. Also I tried using the backlash settings and shuttle settings, and that only made the steps worse. I also tried CV mode and Exact stop.
The work piece isn't shifting.
To see if it was a mechanical problem I switched the pin settings for the x and y axis and the 'steps' also switched sides. So I believe this to not be a mechanical problem, but a software setup thing.
Mostly I was trying 2"x1" pockets, 1/8 to 1/4 inch deep and going in 1/16 step depths. I have also tried this on 2x2 and 3x3 pockets all with the steps showing up on the same side and getting bigger as the pocket gets bigger.
The system is:
G540 gecko
48V Meanwell PSU
300oz or so steppers
Mach3
Spindle: laminate trimmer(securely held, and not shifting in the holder)
So please any suggestions on what I have missed would be helpful.
Attached is the gcode and a pic of one of the cuts. They generally al look like that. Some with bigger steps.
Old 05-22-2010, 04:14 PM
ger21's Avatar
Try 15 or 20.
Old 05-22-2010, 04:41 PM
It worked! Thanks Gerry. The screen in motor tuning makes it look like you can't put it above 5. Not to sure exactly what those settings do, but 15 did the trick. I can't duplicate it on large cuts as I am going out now, but it seemed to fix the problem.
Two days of pulling hair out, solved in an hour.....
Old 05-22-2010, 05:46 PM
ger21's Avatar
It's a common issue with the G540. I think it's caused by poor quality signals from the PC, but not exactly sure.
Old 05-22-2010, 09:52 PM
jsheerin's Avatar
jsheerin is on a distinguished road
That was my problem with the G540 - my PC's parallel port card could not source enough current to drive the opto-isolators in the G540. Thread about it here:
http://www.cnczone.com/forums/showthread.php?t=75784
I figured out my problem starting around post 15.
Old 05-22-2010, 11:31 PM
Well the original poster on the thread had many of the same problems and questions I did. I am hoping that the fix Gerry just gave me holds out and I don't have to buy a smoothstepper or another lpt card. Frankly I am at the point where I am don't investing large amounts of money into the machine and have basically tapped myself out of money I could spend.
So this better work or else I am selling this and buying a carvewright! JK
Old 05-24-2010, 08:13 AM
jsheerin's Avatar
If that is your problem, a parallel port card is about $10 plus shipping.
Old 05-24-2010, 02:05 PM
ger21's Avatar
If it doesn't limit your speed, you can increase the pulse width up to 30-40, if you need to.
Old 05-24-2010, 02:24 PM
jsheerin's Avatar
If the problem is insufficient current in the lpt port, I still don't see how increasing the pulse width helps this. I mean I know it does - it did on my machine at least some of the time. But looking at the input voltages to the G540 on a scope, increasing the pulse width did not make the voltage of the step pulses rise to a level that would make me think the G540 could see the pulses.
Tags
drift, lost steps
Need Help!- z-axis drifting down and errors 409, 449 Dale C Milltronics 5 05-24-2010 08:38 PM
Problem- partner 1 z axis drifting , encoder??? fcycles Milltronics 2 03-25-2008 08:39 PM
X AXIS DRIFTING +/- .005 WORKALONE Fadal 4 03-03-2008 10:10 AM
Z-axis drifting down Vogavt Machine Problems, Solutions , Wireless DNC, serial port 4 10-23-2007 03:04 AM
Router Z axis drifting down! cnctygrys Commercial CNC Wood Routers 3 08-13-2007 10:13 PM
