Old 05-19-2010, 12:46 AM
toneV8 is on a distinguished road
CNC router 2200mm x 1600mm x 350mm
I want to build 2200mm x 1600mm x 350mm working area approximately 86'' x 63'' x 14'' cnc router. I plabne to buy supported linear rails and anti blacklash ballscrews from linearmotionbearings2008 Chai. Machine will be made from steel tube 130x100x10mm, 100x100x8mm and 80x80x6mm.
Is ballscrews and nuts C7 from linearmotionbearings2008 really anti blacklash.
What diameter and lead 5mm or 10mm is best for this size machine and electronics.
Is this electronics from kelinginc good for this size machine or to find something else.
NEMA 34 Servo Motors 4 Axis CNC Kit:
4 PCS Geckodriver 320,or G320X, 80V/20A
4 PCS KL34-180-90 (NEMA 34) Dual Shaft, 1125 oz-in Peak
90V/40A
4 PCS US Digital: E5-500-250-N-S-E-G-2 Individually Packaged
Shaft-Mount Optical Encoder with latching connector, 500 CPR , fit
1/4" diameter shaft. Molded mounting ears for 1.812" bolt circle
(with Installation Tool) + 4 PCS CA-FC5-SH-NC-6 Connector
Encoder Cables
1 PCS KL-7220, 72V, 20A, Unregulated Power Supply, 110V/220V
5V power Supply, 110V/220V
1 PCS Breakout Board for 6 axis, Isolated signal, E-Stop or Limit Switch can be
wired
Old 05-20-2010, 11:57 AM
So no one have any suggestion to help me.
Old 06-10-2010, 12:15 PM
I change my mind not tu buy from linearmotionbearings2008. I decide to buy Hiwin HG 25-R rails and HGW 25-HC-ZO-H super heavy duty blocks. Are they good to use for all 3 axis.
Rails:
HG 25-R 2x2600mm
HG 25-R 2x2000mm
HG 25-R 2x700mm
HGW 25-HC-ZO-H 12 bloks
Old 06-10-2010, 12:28 PM
louieatienza is on a distinguished road
Rails:
HG 25-R 2x2600mm
HG 25-R 2x2000mm
HG 25-R 2x700mm
HIWIN makes some really nice stuff, though I never used it....
Old 06-10-2010, 04:47 PM
Bear5k is on a distinguished road
Hiwin changes the part number slightly when you go from the basic linear bearing through to the highest accuracy ones. This has a big difference in price tag, and may or may not be noticeable on your machine. In general, you are probably no worse off, but low-end Hiwin is not the necessarily the same as THK or NSK.
Old 07-08-2010, 12:06 PM
Smile
Hiwin goods just come.
Name:	Hiwin rails 1.JPG‎
ID:	110525   Click image for larger version
Name:	Hiwin rails 2.JPG‎
ID:	110526   Click image for larger version
Name:	Hiwin blocks.JPG‎
Old 07-08-2010, 12:32 PM
Khalid's Avatar
Khalid is on a distinguished road
Very Nice decision on THK..What is the price of the rails and blocks?
http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
http://my-diysolarwind.blogspot.com/
Old 07-08-2010, 12:40 PM
It is not THK it is Hiwin.
Price 1200€.
Old 07-09-2010, 11:24 AM
Is it good idea to use A4 grade 18/8 ( 316 S16 ) stainless steel hex socket cap screws for rails.
Can someone suggest what kaind type Hiwin ballscrews to use, there are so many.
Old 08-06-2010, 12:34 PM
I got prices for Hiwin ball screwss:
dia 20mm lead 5mm 930mm long with nut and end machined ball screwss peeled 630€
dia 25mm lead 10mm 930mm long with nut and end machined ball screwss peeled 670€
Hiwin end supports 370€ fixed and 95€ floated
It will cost me fortune for all 3axis.
Hiwin rolled cost much less 20-5 1000mm 30€, nut 75€ but accuracy gradeIT7 ball screwss 0,052mm and nut 0,02mm ( oversize balls ).
My question is: how good IT7 grade is for machining wood, plastic, aluminium, when machine work couple hours engraving, cutting something, what dimension will part have. Is with IT7 backlash will be to big.
For end supports I plane to buy chinese end supports BK and BF and replace bearings with SKF bearings.
Need Help!- with a Precix Table Router with Perske router SignShop Grunt General CNC (Mill and Lathe) Control Software (NC) 7 09-08-2010 04:08 PM
CNC ROUTER KIT instructables router project spotlight3d EBAY ADS 4 12-30-2009 04:11 PM
Build Thread- Building a CNC Router; by someone who can't build a CNC Router Womble DIY-CNC Router Table Machines 2 09-27-2008 07:51 AM
Using a router for the 1st time. Need advice of cut speeds, router bits etc. Apples DIY-CNC Router Table Machines 19 09-23-2006 03:33 PM
Surfcam PP for Isel router / Precix router IvanTochev Post Processor Files 2 05-12-2004 12:27 PM
