Old 05-16-2005, 11:15 AM
Aegeon is on a distinguished road
timing belt question
I'm currently designing my router table, a 4'x8' table for routing in wood only (i figure 80% MDF, 20% other hardwoods). My gantry design calls for dual timing belt drives on each side of the X axis, and single belt drive on the Y (linear rail/ballscrew for Z). The X and Y axis use BishopWisecarver DualVee guide wheels and tracks (tracks not shown in the rendering). In working out pricing for the belts, pulleys, idlers, etc, I'm finding the pulleys are fairly expensive, especially for 3/4" and wider belts.
My question is, what size belt is really needed for each axis? I figure the gantry will weight about 60lbs... Any suggestions? I dont want to buy 6 $25 pulleys if they're not needed....
Thanks,
Aegeon
A rendering of the gantry is attached. Please ignore the Z-axis, the design has changed significantly.
Old 05-16-2005, 11:56 PM
2muchstuff is on a distinguished road
I wouldn't see a need to bigger than a L series or smaller than an XL series. I would use a Kevlar reinforced belt to lessen the effects of stretching.
If it's not nailed down, it's mine.
If I can pry it loose, it's not nailed down.
Old 05-17-2005, 06:54 AM
ger21's Avatar
The 4x8 belt drive routers I've seen all use at least 1" wide belts. GT or GT2 being the best choice. Check out www.sdp-si.com for a lot of good belt info.
Old 05-17-2005, 09:09 AM
mxtras's Avatar
Silver Member
mxtras is on a distinguished road
I use a commercial 5'X16' machine. It has medium sized steppers (not sure of the actual frame size) with a 3:1 reduction to rack gears - they chose a 3/8" wide XL belt.
Scott
Old 05-17-2005, 10:43 AM
ger21's Avatar
I'm talking about using the belt as the rack, your talking about from the stepper to the pinion, right?
Old 05-18-2005, 01:10 AM
mxtras's Avatar
Silver Member
Sorry!!!
Yes - I am talking about the motor to the pinion.
Scott
Old 05-18-2005, 09:50 AM
jcc3inc is on a distinguished road
Sir,
I have always been a fan of rack and pinion; you can see the machine I made in the preceeding Skate Wheel posting. My particular setup uses direct drive from the stepper to the rack thru a 2" circumference drive pinion (circular pitch rack) and having 10x microstepping giving a distance per step of .001". The machine runs smoothly form the microstepping. If one were to use the 33 frame steppers, you can get quite a bit of torque from them in direct drive, or you can gear them down for more torque.
Your design looks a lot like the Shop Bot!
Regards,
Jack C.
Timing belt length calculator. dmgdesigns DIY-CNC Router Table Machines 2 01-05-2009 06:54 PM
timing belt reduction drwc Benchtop Machines 6 05-23-2005 03:31 PM
Timing belt/ratio question kinneycan CNCzone Club House 3 09-24-2004 04:20 AM
Any recommended Timing belt and pulley? starCNC General Metal Working Machines 10 07-31-2004 11:29 PM
Should you put grease on a timing belt? ynneb DIY-CNC Router Table Machines 5 04-22-2004 08:54 AM
