Old 05-16-2010, 01:47 PM
tcdk is on a distinguished road
Joints to fit ALU
Hi
Im starting to plan building my own CNC router.
I have access to about 250 meter ALU profiles in different shapes, dimensions etc.
Im thinking in building the frame in 100x30mm (3mm thick) and 50x50mm (3mm thick)
I will have to make some sort of couplers/assembels, that I can router out with a Copy router for alu (old but good machine)
Im thinking in making it something like this, and make threaded holes.
I will use largeheaded umbraco-bolts.
It will look something like this:
The machine should be used to wood and plastic, but ALU would also be nice.
The dimensions on the cutting area, should be around 800x1200mm
Will the ALU profiles I have be "strong" enough for this?
If there are any words you don't understand, please let me know. It's not always easy to find the right word when translating
Old 05-16-2010, 04:04 PM
stk2008 is on a distinguished road
Why not use rexroth
http://uk.rs-online.com/web/search/s...%29#breadCrumb
Old 05-17-2010, 01:55 AM
Originally Posted by stk2008 View Post
Why not use rexroth
Because I have the other alu-profiles for free.
Old 05-17-2010, 05:11 AM
louieatienza is on a distinguished road
Best reason! Good luck with your build! Looks very strong...
Old 05-17-2010, 09:28 AM
I will post a complete drawing when it's about finish.
Drawer joints on 3 axis CNC huntycnc WoodWorking 28 03-03-2011 10:03 PM
2000 VF0 CRT failure, solder joints gar Haas Mills 0 05-20-2006 08:37 AM
Universal Joints Robyn Product Announcements & Manufacturer News 0 03-22-2006 04:59 AM
Dovetails and box joints with CNC db113 WoodWorking 12 10-13-2005 07:19 PM
Adjustable tubing joints source??? CoffeeRich Hobby Discussion 3 08-16-2004 10:44 PM
