Old 05-15-2010, 12:41 AM
coloradonewbie is on a distinguished road
Is the belt drive system on the Zenbot available?
I was just looking at the belt drive system on the new Zenbot and was wondering if there is a source for the stepper motor housing or mount setup they are using for the drive belts. It mounts the motor at a 90 degree angle to the surface and covers the pulley and belt I suppose.
http://www.zenbotcnc.com/merchant2/
They are talking about 800 - 1000 ipm rapids with this table!
If I can build a machine with belts instead of screws and simple mounts like that and also get wicked fast rapids, I'm all for it.
I was watching the YouTube videos on it and it looks really fast. I didn't think belts would be that accurate. Guess I was wrong.
Thanks in advance.
Old 05-15-2010, 08:40 AM
jsheerin's Avatar
jsheerin is on a distinguished road
You could buy a motor mount from cncrouterparts.com and adapt it to your purposes. However it looks like they might have a shaft with some bearings on both ends on that machine which would probably be a good idea. It wouldn't be hard to design and you could probably get someone to make them for you pretty cheaply if you can't make them yourself.
Old 05-15-2010, 10:11 AM
Kipper's Avatar
Kipper is on a distinguished road
Why have super fast rapids on a tiny machine...No sooner has it set off than it has to stop.....
The drive system ie belt drive is so simple to make...just 5 holes and screw it to the front frame...an idler at the rear and it's done...watch for racking when machining at the outer edges.....or fit 2 belts.
Keith
Old 05-15-2010, 10:34 AM
nofx is on a distinguished road
need for speed in life is why. IPM looks better then resolution and repeatablity. I will be drag racing my machine too.
Old 05-15-2010, 01:44 PM
jsheerin's Avatar
I would rather go for increased force and thus acceleration plus better resolution on a smaller table. Maybe cut the rapids in half to 500ipm. That's still better than a lot of people here get by with on larger machines. Mine is 4'x4' and I rapid at 200ipm. My next one I'm aiming for 1000ipm, but that will be more like a 5'x10' table, and I'll have high resolution and acceleration as well due to over-kill surplus servos.
Tags
zenbot componants
Direct Drive Vs Belt Drive for a Mill/Drill Retrofit? pfeist General Metal Working Machines 11 02-13-2012 02:12 AM
New Machine Build- Dynatorch on a belt driven system KPT DynaTorch 4 03-18-2009 09:55 PM
Newbie- Belt drive or direct drive? rholliday General Metal Working Machines 2 02-16-2009 05:21 PM
Need Sherline Belt & qestion on X2 Belt Drive? Oldboy Benchtop Machines 12 03-06-2008 12:42 AM
What is Belt Drive system? Oracle_9 Mechanical Calculations/Engineering Design 18 12-20-2005 09:20 PM
