Old 05-10-2010, 04:13 PM
LessPaul is on a distinguished road
Endmill to cut aluminum with high speed router?
I know I've seen it somewhere, but after 10 minutes of looking I admit defeat. I read on one thread or another that there are special router bits / endmills for use on high speed (wood) routers that will cut aluminum. I want to do some simple milling using my Bosch Colt and thought I'd give it these bits a try, if I could only find them!
Thanks much -- Paul
Old 05-10-2010, 04:58 PM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
standard end mills work well enough with a router
A poet knows no boundary yet he is bound to the boundaries of ones own mind !! http://cnctoybox.org
Old 05-10-2010, 05:00 PM
ger21's Avatar
www.onsrud.com
Newbie- High feed endmill mackie29 Hard and High Speed Machining 1 02-27-2010 06:52 PM
Just IN- High Precision, High Speed Bearings mikeyg Product Announcements & Manufacturer News 0 09-07-2009 07:06 PM
Have High Speed Modem, and Dial up Using Router tobyaxis Computers and Networking 46 07-23-2006 09:17 PM
High-Speed 3 (4?) axis cnc router rherman DIY-CNC Router Table Machines 29 10-20-2005 10:31 PM
3 Flute High Helix Endmill Problem Joe_CNC General Metalwork Discussion 7 07-19-2005 07:07 PM
