Old 05-11-2005, 05:22 PM
js530 is on a distinguished road
Leadscrew or Acme for Al. Router
I am building an aluminum framed CNC router, mainly for injection molds, PCB's, and some MDF stuff, but I have yet to decide on leadscrew or acme threaded rod. I have two 12" lengths of lead screw (salvaged from some semi conducter equipment) with antibacklash nuts, but I'm afraid they will be too short. 8-10" of travel is too small. 20" of X travel with 12" of Y and Z travel is fine. Will 1/2" 10 tpi acme threaded rod be stiff enough for milling aluminum? I have three identical steppers, 24 volts at .1 amps 1.8 degrees/step, but I also have two larger (nearly twice as big) steppers with unknown ratings. I only have two, and getting a third would be nearly impossible. Should I use the three identical steppers or use the two big ones for XY and a smaller for Z?
Old 05-11-2005, 05:50 PM
joecnc2006's Avatar
www.joescnc.com
joecnc2006 is on a distinguished road
I think the 0.1a will not move anything, what did it come from?
you usually want a stepper motor with low volts and high amps. maybe i'm mistaken?? Anyone?
Old 05-11-2005, 06:53 PM
It was new old stock, some IBM part.
Old 05-11-2005, 07:23 PM
DieGuy's Avatar
DieGuy is on a distinguished road
Yep low volts and high amps and then drive them at 10-20 the voltage rating if the windings are rated that high.
A better questions to ask, if you are milling aluminum for molds are:
1) what kind of tolerances need to be maintained?
2) what are you going to use for a cutting spindle? And what kind of runout does it have under load?
3) how much torque does it take to move the Amce screw with no load and the lash tightened up?
Finding The Right Router Crushmonkey Commercial CNC Wood Routers 22 06-19-2006 01:17 AM
Acme leadscrew or Trapezoid leadscrew is better? minicnc DIY-CNC Router Table Machines 3 03-07-2005 11:57 AM
A source for 1/4 - 4 acme leadscrew? cheap of course! fyffe555 DIY-CNC Router Table Machines 6 09-15-2004 01:10 PM
Acme leadscrew size selection info jeffs555 DIY-CNC Router Table Machines 0 06-13-2004 09:31 AM
My first CNC router: 1.5 years building hddjohns DIY-CNC Router Table Machines 2 04-03-2004 10:18 AM
