Old 05-03-2010, 04:13 PM
studysession is on a distinguished road
Help from the pro's
Hi -
I want to build a small table top CNC router using printer parts. I was pulling a printer apart today and saw that it uses DC motors instead of stepper motors. I know I can just switch them out but at same time I would like to get it working as is.
I use Mach 3 software to control my stepper motors on my bigger machine which is in pieces right now.
What motor controller would I / should I use to control some small 3 - 5v motors and use Mach 3 as my controller software.
Any help and input would be appreciated so thanks in advance...
It would be really great if I can make a small table top gantry router from printer parts.
Please check out my CNC blog
http://cncinside.com
BOB Features Pro's and Cons Al_The_Man Polls 2 05-09-2009 06:49 PM
Pro's and Con's for both rods and rails?!?! cvriv.charles Open Source CNC Machine Designs 6 05-08-2009 10:42 PM
DRO PRO'S Easson read-out Huck_This General Electronics Discussion 0 12-14-2008 08:24 AM
What Software do you use along with the PRO'S and CON'S Revtech DIY-CNC Router Table Machines 8 07-17-2006 04:16 PM
Pro's Con's, what to choose? GalaticDan Servo Motors and Drives 2 06-06-2005 03:01 AM
