Old 05-01-2010, 09:06 PM
scotta is on a distinguished road
Hybrid Evolution taking shape
Over the last year I have been collecting parts for a CNC Router. Initially I was going to build a Joes 4x4 Hybrid but then things started to evolve. I have enough room in my workshop for a 4x8 and it sure would come in handy to have the large cutting size every now and then ;-)
So I started to adapt the Hybrid to a 4x8 and incorporate rack and pinion drive on the X and Y axis, ball screw on the Z. My first pass was to use MDF as per Joes Hybrid but then of course 8020 and aluminium plate would be nice, a bit stiffer and less prone to damage. So the design evolved and evolved and now I'm starting to be quite happy with the result.
As I don't have any CNC capabilities I needed a design which could use MDF parts as initial structural members to get the router up and going before CNC machining the aluminium plates, So a two step build, firstly a combination of 8020 and MDF and then 8020 and Aluminium. I hope.
The orange X carriage was my initial MDF design.
ID:	106214   Click image for larger version
Old 05-01-2010, 09:23 PM
A couple more pics. I am planning to mount the ball screw through the centre of the 8020 extrusion to get the spindle overhang to a minimum.
ID:	106217   Click image for larger version
Old 05-02-2010, 01:55 AM
Jesse B's Avatar
Jesse B is on a distinguished road
Very nice looking renderings. Looking forward to seeing this come together.
Old 05-02-2010, 08:32 AM
geezergeek is on a distinguished road
RE: Hybrid Evolution Taking Shape
Is the gantry assembly drawing not yet complete, or are you really planning for the gantry to be "{cantilevered} over the main table area? With your table already so large the ends could left in the design as a part. of the gantry. Thanks for the clarification in advance, Joe (NO, NOT THE Joe who apparantly designed the Hybrid). What application did you use to create the renderings? Good Job!
Old 05-02-2010, 06:35 PM
No, drawings still in progress. I did a quick mirror over to show what it will eventually look like. Support frame still needs bracing but I'm thinking some cupboards in the base would be handy.
Modelling is in Inventor as well as the renderings. I'm tempted to do some in 3DS but I might wait until the end.
Scott
ID:	106299   Click image for larger version
Old 05-09-2010, 06:56 AM
Finally got a little more work done on the rack and pinion drives. I purchased all the pulleys and bearings ages ago from Stock Drive Products before CNC Router Parts brought out the R&P unit so I am kind of stuck with what I have. I am using a higher reduction which will suffer at top speed but for a gain in accuracy and torque at cutting speeds.
Has anyone used the 8020 Anchor Fasteners to connect a plate to the extrusions? I thought that it might give a neat connection to the side plate of the Y Carriage. Any thoughts?
Scott
ID:	106709   Click image for larger version
ID:	106710   Click image for larger version
Old 05-11-2010, 03:35 AM
I've been tossing around a few ideas for tensioning the R&P drive. Turn buckles take up a lot of space so this is my take on using a compression spring. A little more time consuming to make but should do the job I hope.
Scott
Old 05-11-2010, 09:56 PM
Nearly there... Z axis to complete and then some cable management.
ID:	106985   Click image for larger version
Old 05-14-2010, 08:35 PM
X-Axis carriage nearly complete...
ID:	107202   Click image for larger version
ID:	107203   Click image for larger version
Old 05-14-2010, 08:37 PM
A couple of orthographics... Does anyone have a CAD model of a 2.2kW water cooled spindle? and a spindle mount?? Would be much appreciated.
Thanks Scott
ID:	107207   Click image for larger version
  #11   Ban this user!
Old 06-13-2010, 08:45 PM
Design is getting closer to being finished. Day to day life and work just seem to get in the way.
This pic is not a rendering... this is the new modeling environment in Inventor, oh so nice but hungry for computer resources.
Genesis Evolution sleblanc CNC Machining Centers 13 02-08-2012 11:43 AM
The Evolution of a Home CNC Mill Stevie Vertical Mill, Lathe Project Log 116 05-21-2010 05:31 AM
Need Help!- DMU 50 evolution sguru007 Deckel, Maho, Aciera, Abene Mills 3 12-29-2009 02:44 PM
How/what machine to shape a thin stainless plate to become a "half" egg shape ? Calico General Metalwork Discussion 5 03-24-2007 09:40 AM
