Old 04-30-2010, 07:51 PM
rlwoodjr is on a distinguished road
Spin the nut with Arduino servo drive
I have some servo motors with 500 CPR encoders. I always thought it would be cool to have a router with servo drives.
Since the motors spin at 3000 to 4000 with 50 VDC, and I my X axis will be 48" long....I need to spin the nut to eliminate the lead screw whip.
So....I made a timing pulley with threads through the middle, with bearing shoulders
Old 04-30-2010, 07:54 PM
Then I made a temporary setup to do some resting...
ID:	106161   Click image for larger version
Old 04-30-2010, 07:57 PM
I also built a h-bridge motor drive to connect to the Arduino.
I have programmed the Arduino as a PID controller that takes step and direction inputs, it works ok, but I need to make some modifications to the PID program.
For the moment I am using a:
3/8-16 threaded rod
50 VDC power supply
Mosfet H-bridge (still needs some tweaking, sometimes it catches on fire)
An Arduino (these are great micro-controllers that are easy to program)
24" long linear 3/4" linear rails
TurboCNC for generating the steps and direction input
I am moving at 200 IPM (each step is 0.000125)
Old 10-27-2010, 12:45 PM
I have got a motor driver that looks like it might work. I have posted details in the open source controller boards.
My new CNC machine. Arduino controlled: aventgps Open Source CNC Machine Designs 45 05-03-2012 11:39 AM
Arduino Mega driving my cnc. aventgps Videos 2 12-30-2009 01:57 AM
Newbie- CNC Lathe - Servo direct drive or pulley drive? s76tools General Metal Working Machines 1 09-06-2009 11:17 AM
Galil Motion Controller, with NEMA 23 Servo Motors, Servo Drive, Encoders, Etc. qualitymachine EBAY ADS 0 06-01-2009 02:26 PM
Need Help!- Arduino AlienCNC C control gremilRoute General Electronics Discussion 6 04-23-2008 04:02 PM
