Old 04-24-2010, 05:54 PM
Trucks is on a distinguished road
Quick Need help with Mach 3!
Hey guys,
Not sure this post belongs in this section, but i didn't see a better place for it.
I have had my machine for 8 months now, and when I use it I work in inches, thats what the machine is set up for.
Now I have some parts that are metric, so I am using MeshCAM and it gave me all the G-code and I told it that the parts were in MM so it made it correctly.
I get it to my Mach 3 downstairs and there is no G21 in the code, so I added it at the top, but nothing happens.
HELP!
Thanks for any advice!
Andy
Old 04-24-2010, 06:35 PM
ger21's Avatar
The easiest way is probably to scale it in MeshCAM. When you import it into MeshCAM, choose inches. Then, go to Scale Geometry (Geometry Menu) and check "Uniform", and scale by 0.03937007874015748031496062992126
Your code will be in inches, and the part should be the same size.
I posted the above because I don't really know what the problem is. Did you use the Inch post, or the mm post in MeshCAM?
Old 04-24-2010, 06:45 PM
ger21's Avatar
Re-reading your post, I see that you didn't actually say what the problem was?
Old 04-24-2010, 07:01 PM
Sorry,
The problem is this. I go into meshcam, load the part in "mm" and when it compiles everything and I open it in Mach 3, the code is in mm but the machine seems to be thinking 100mm is 100 inches because it just keeps going and going and going, so I will do the conversion.
Thanks!
I think that will be the fastest way.
Old 04-24-2010, 07:21 PM
ger21's Avatar
If you actually run the part with the G21, everything on the Mach3 screen will appear the same, but the machine should be moving in mm instead of inches. Without actually running the machine, you won't see the difference.
Old 04-24-2010, 09:35 PM
Well thats what I thought, but i must have something wrong somewhere. Its ok I just did the scale Idea and that works out just good enough.
Thanks Gerry!
Andy
P.S. I will post a picture of what I am making when I am done
Need Help!- Servo Drive Card for Mach II / Mach III umarcnc Mach Mill 2 02-21-2010 02:37 AM
Quick question about MACH 3 and axis settings? max90272 Mach Software (ArtSoft software) 7 10-17-2008 03:48 PM
Confused: Mach Turn, Mach Mill, Mach 2/3 ? CanSir Mach Software (ArtSoft software) 5 02-16-2007 04:41 AM
Quick Code, Visual Quick Code 1ctoolfool Haas Mills 1 09-17-2006 10:46 AM
Need Mach 2/3 Wizzard Quick! elalto Employment Opportunity 4 07-19-2005 11:44 AM
