| Hi guys, I know that threads about resonance dampers have been done to death on here, but I have an idea which I haven't seen before in order to make them quiet. First let's look at how I see the "rattlers" working. Yes, "centrifugal force" does not really exist but I will treat it as a real force in this as it fits well. Let's look at a single hole in the rattler: ![]() Here you can see the metal pin inside of it's oversized hole. As the damper spins, the "centrifugal force" forces the pin outwards in the same way that a spring would. The pin centers in the hole to rest in it's natural position. When a change in angular velocity happens, (I.e. It speeds up or slows down.) inertia forces the pin either to the left or the right. As the "centrifugal force" still exists pushing the pin outwards, the sideways force must overcome the outwards force in order to follow the curve of the hole and move sideways. This wastes some of the sideways force, dampening it: ![]() If we were to represent this as a spring-mass, it would look something like this: ![]() So the first method to make it quiet would be to turn it into the spring-mass system shown above, but this would be harder to make. This is actually very simelar to the split-flywheel separated by rubber method which I've also seen on these forums. So how can we make the pin-based rattlers quiet ? Well first of all let's look at the hole. We don't need the hole to be round as the pin, when the damper is turning, should never be pulled inwards past the half-way mark. With this in mind we can change the cutout to be this shape: ![]() The second thing that we can do is to line the inside of the cutout with a thin piece of rubber. This can be a thin-walled tube which has been put in a cutout of the correct size. Is this idea new or has it been done before ? Finally, as a bit of an aside - If I were to get a 60mm diameter bar of Delrin and cut a 30mm thick chunk from it, what would be the best way to clamp it to my CNC Router ? I only have a T-Slot table on it. Thanks, -Andrew. |
| Might be worth trying, and it seems to have merit. I haven't seen one like this so far. You could even add oil in the cavity for grins if you can seal it well enough. Different viscosity oils will have an effect on how it operates. CarveOne
__________________ CarveOne Resistance is not futile. It is voltage divided by current (R=V/I). |
| The oil may do wonders in terms of quieting it, but I'm not sure what it would do in terms of performance. (I.e. Resonance removal.) To seal it you could just put a rubber o-ring around each cutout - Quite a bit of extra work but if it's being done on a CNC it shouldn't be a problem to get right. If anybody is in a position to quickly and easily try making a prototype of this that would be really awesome. |
| Why not try making Greg's silent dampers. My take on a stepper damper
It appears I'm suffering from the resonance problem on the Y axis as at times it will suddenly stop and growl very loud unless going at 30 IPM or lower. The lead screws do have some wobble to them even though I tried to straighten them. I have single shaft nema 23's on the router so I will swap with the double shaft steppers that are on my X2 and I want to make Greg's silent dampers. I didn't find where he posted his results though. I'd like to know how they ended up working for him, any idea ? I'll post some pics of my rig soon, I didn't have a clue as to what was causing my problem at higher IPMs until I read about it here a few days ago, the Zone to the rescue again, thanks ! Steve |
Mine aren't silent, but might be easier to make. My take on a stepper damper My take on a stepper damper
The only thing that I have against the design is the hub - I'm not a fan of setscrews as they mark the shaft. I prefer the split clamp so would probably change that: Thanks. ![]() |
Wow, I guess that I saw it but it didn't sink in as my eyes were drawn to the pics, easily distracted you know thanks. Yeah, I saw yours, they look good and it was your video that really made me realize I had the same problem.I already have the urethane and I have some 2" steel rod to turn them out of, I don't have a knurling tool so I think I'll just turn some grooves into the center part and make some grooves perpendicular to those. I know he said the dimensions were a guess, I hope 2" OD will be good (?) His looks like they may be 2-1/2" dia.
I hope you're right about that in my case too. We'll see. |
| My take on a stepper damper | S_J_H | Stepper Motors and Drives | 248 | 05-04-2012 03:22 AM |
| Build Thread- $1.50 per axis Dirt Simple Damper | THend | Stepper Motors and Drives | 12 | 12-13-2010 07:13 AM |
| Opinions on this stepper damper? | johnmac | Stepper Motors and Drives | 0 | 01-22-2009 09:37 PM |
| Damper on the Stepper motor | abomination | Stepper Motors and Drives | 2 | 05-28-2007 05:55 PM |
| Vibration Damper | tachus42 | Stepper Motors and Drives | 6 | 11-17-2006 10:57 AM |
