I'm starting to look into making a router table. I've been looking at a few sites, namely buildyourcnc.com to see what goes into it. I feel I have the mechanics down at least as a whole though I'm sure there are some finer points I'm not yet aware of. I will most likely change his design to suit, and not use much (if any) MDF, instead use BB ply, steel and aluminum to make it more rigid. The electronics/control side of it still has me a bit baffled. As I understand it I use autoCAD and save the file as a DXF, use another program to convert that to g-code then use (mach3 for instance) to use that g-code to control the operation. Question 1.) What exactly am I drawing in CAD? The path I want the router to take? If so then do I use the z axis in the drawing to define the cut depth? Question 2.) What if I need to change to a different bit? How is that represented on the drawing? For the actual control as I understand it the computer communicates with a breakout board to pass commands onto the steppers. I've looked at the one linked to on buildyourcnc.com as well as others and there seems to be quite a variation. They all seem to have the same type of control, i.e. x-step and x-direction, etc. but the pinouts of one board doesn't always match a different board. Question 3.) Do I need to manually change the wires in the parallel cable or can I define the pinouts in the software? Or is there a certain standard I need to adhere to? Question 4.) Is there an advantage in having a separate breakout board and motor drivers or is an all-in-one board o.k.? I know I have a lot more reading to do and you've probably answered these questions a hundred times for newbs but I'm hoping you guys can narrow down for me what I should be concentrating on. Thanks for any help in advance! Ryan |
![]() - Jesse |
| Tool changes are defined as part of the gcode generation process. You will define the cutter sizes as Tool 1. Tool 2, etc. Each tool number is a specific size and/or type of cutter. You will need to manually adjust the cutter length to the correct height during the tool change before resuming the program. Automatic tool changers can do all of this for you in a production environment. Most home built machines don't have these, though some folks just gotta have one anyway. ![]() CarveOne
__________________ CarveOne Resistance is not futile. It is voltage divided by current (R=V/I). |
| hanks for the feedback! I've been thinking for the electronics I'll probably just get a kit. I've seen the G540 mentioned many times so I'm assuming it's a popular and well accepted controller. At least that way I'll get a system known to work well together than spend a lot of time and effort to 'hopefully' get something that works well together to save maybe a $100 or so. For instance something like this.
Another newb question - I see 4 axis kits available. I can't think of what that 4th axis would be for. The only thing I can guess at is tilting the cutting head, but if you were going to do that wouldn't you want a 5 axis to be able to tilt the head in 2 directions? Thanks again, Ryan |
| Youre right! The 4th axis is (sometimes) to tilt the cutting head on one plane. Other axis can be to tile the cutting head on other planes. However, there really isn't a standard for this - something becoming popular is to have a rotary table set up as the 4th axis - e.g., you put a long piece of wood in a setup that is very much like a lathe, but the wood material is rotated under the cutting head by a CNC stepper motor, and the cutter moves up and down and across the piece to carve up columns, etc. |
I know *.DXF works for sure, but I'm not sure of what others do, but I'm fairly certain there are more.As for PCBs, you obviously just design then in 2d. If you use Eagle (freesoft PCB layout and schematic software), there's a very easy-to-use plug-in available called PCB G-Code, which will automatically create the G-Code for isolation routing the PCB. You just set up the preferences, and it does the rest. - Jesse |
| Need some guidance | scrambled | General Electronics Discussion | 10 | 02-21-2009 01:32 PM |
| Looking for a little guidance! | jayty97 | DIY-CNC Router Table Machines | 3 | 02-14-2007 08:43 PM |
| In need of guidance | xcphil | General Metal Working Machines | 0 | 05-29-2006 01:41 PM |
| I need a little guidance please.... | Steve F | Servo Motors and Drives | 5 | 05-15-2006 01:16 AM |
| Need some CNC guidance | seafire | CNC Plasma and Waterjet Machines | 2 | 11-15-2005 10:07 PM |
