| So I have been lurking on here from a few months now. Unlike most of the guys on this great forum I chose to start my build before actually doing any research in to what I should do! I just dove in head first and started buying stuff at the local Hardware store. After waisting 100 bucks or so on failed linear guide solutions I finally bought some parts that actually work. And now finally I have a fairly accurate machine. It still needs some tweaking, the bearing blocks are still just mdf and I need to enclose my controller board. It at least works for its intended purpose, drilling holes for a diy microphone capsule. It is also busy building better parts for itself! I am attaching a video of it drilling some holes. let me know what you all think. And trust me, I know it could be much better. In fact I'm already looking out for some aluminium to upgrade the z axis. Thanks for looking!!!! Eric |
| Nice first build. I would recommend replacing the Dremel tool with a 1/4" trim router. Even the one Harbor Freight sells. The added power and wider selection of 1/4" shanked bits is well worth it. (That's what I did) John |
| Great work. That's one of the cool things about CNC projects - solving problems and getting the job done on a modest budget. It's a home run. There's always room for improvement, but now you have a base (knowledge and physical) to build on. Steve |
#12
| So looks the video works for some of you but not others. Interesting. As for components..The fram is 100% 3/4 inch MDF. The motors I orderd from All Electronics. They are cheap!! only 9 bucks a piece. They work great though. The lead screws are 16tpi and I bought them from a guy on ebay. They are just ok, that is something I would love to eventually upgrade. The board I also bought on ebay from Lightobject model TB6560T3V1. It works very well and was pretty easy to setup. Im using the 1/16 micro stepping and the resolution seems to be very good. For power Im just using a 12v supply that I converted from a PC. I had planned on buying a 24v but 12 seems just fine for what Im doing. I used linear rail on the x table(ebay) not sure on the brand. And 12mm linear rod from Mcmaster carr and 12mm bearings from ebay. The 12mm works very well on the z axis but has a little flex on the y axis. If I had done my homework before buying I would have gone with 20mm rods and bearings on the y axis to reduce flex. Oh well something to upgrade latter! For the most part it works great. Fun learning experience. I do plan on using most of these components on an all aluminum buid someday in the near future. I just need to get a drill press and some taps before I go down that road! Eric |
| Newbie - To build or not to build Router/Plasma Table | dfranks | CNC Plasma and Waterjet Machines | 10 | 04-07-2011 11:16 PM |
| Starting a practice table (with extra-ghetto) | panozeng | Plasma, EDM and other similar machine Project Log | 1 | 02-08-2010 09:53 PM |
| New Large Table Build in Houston, TX (Build Log) | anitel | Plasma, EDM and other similar machine Project Log | 12 | 12-30-2008 02:45 AM |
| Ghetto THC | dz1 | CNC Plasma and Waterjet Machines | 1 | 09-30-2007 11:15 AM |
