Old 04-17-2010, 06:00 PM
ardsranger is on a distinguished road
motor size question
how much oz-in motor do you need.
for working woods and aluminum on a diy mill
250 450 600 1200? any suggestion
table 30x32" if that matters
router
Old 04-18-2010, 01:01 PM
oneturboneeded is on a distinguished road
What are you using for drive? Ball screw, rack n pinion?
What hp router or spindle?
What materials will it be built out of?
Linear bearings? Skateboard bearing?
And overall design?
All of these things need to be addressed, at least a couple before we can give a response. not being rude just trying to help.
-Shawn
Old 04-18-2010, 03:23 PM
ger21's Avatar
Also, how fast do you want to go.
Old 04-19-2010, 10:10 AM
is a link to a post with pics of my project so far
http://www.cnczone.com/forums/showthread.php?t=103528
will start with rack but upgrade top ball screw when i get a littler more free cash
What hp router or spindle? router porter cable
all aluminum
view picks on the link
linear
And overall design?
view pics .. table does not move. z is attached on the x rails
the x rails travel down the y axiss
cut speed im not in a hurry. this is a hobby mil
i will do mostly woodworking on it and some very little aluminum but not much
cut dept 1/4 cutter maybe .5 per cut for roughs cuts.
Old 04-19-2010, 10:58 PM
I think you would be fine with a gecko 540 and nema 23 at 380 oz inch motors like Ahern sells. But im in the building stage so what do i know.
-Shawn
Axis Motor size question tjones14 DIY-CNC Router Table Machines 2 02-25-2010 06:29 PM
Motor size beborracho DIY-CNC Router Table Machines 2 07-10-2007 09:23 AM
motor size? eloid Stepper Motors and Drives 1 03-04-2007 03:40 AM
Servo motor size question. Fabric8r Servo Motors and Drives 11 10-29-2005 02:48 AM
Spindle for metal and wood. Motor size question bgolash DIY-CNC Router Table Machines 2 05-20-2005 11:15 AM
