Old 04-17-2010, 09:51 AM
spaltiel is on a distinguished road
Mach 3 configuration
Hello everyone,
Yesterday I tried to use my kit from Keling with Mach 3 for the first time. I had issues with the motors. I did everything according to Mach 3 tutorials and Keling diagram, however, the motors won't run. I didn't find something which could help me (although I'm pretty sure the solution is at the forum and only I did not find it).
I checked the following:
1. The wiring were o.k..
2. The Estop was not triggered.
3. No warning were inside the Mach 3 software.
4. The motors were locked up.
5. I used 25 pins cable which I wired my self and did new one to make sure it is o.k..
I spent 6 hours checking everything and finally the solution was only to use new profile in the Mach 3 software and also redefine the pins but this time instead of using "Dir LowActive = 'X' " and "Step Low Active = 'X' " I changed both to 'V'. Now the motors work.
I hope it will help someone.
Amir
ID:	105350   Click image for larger version
Need Mach 2 configuration help for Sherline 5410 wilit Mach Mill 14 01-15-2010 07:06 AM
Need Help!- K2 Configuration and Mach 3 SPEEDRE K2CNC 1 07-06-2008 08:45 PM
MACH 3 USB INPUT CONFIGURATION coremfg Machines running Mach Software 5 01-08-2008 08:04 AM
MACH 3 configuration Problems(Sherline) MIAMIVICE Benchtop Machines 3 08-06-2007 07:22 AM
MACH 2 configuration for Xylotex Board ngr1 Mach Software (ArtSoft software) 5 08-13-2004 01:03 AM
