Old 04-12-2010, 11:28 AM
quadtech is on a distinguished road
Tile cutter rail/slides any good?
Looking for a quick-n-easy way to build a small CNC, I was wondering
using the rails and slide from tile cutters.
The better ones have chromed/stainless steel rails and linear ball bearings.
What say you? Just a few examples -
http://www.bontool.com/product1.asp?P=24-131
http://www.plumbersurplus.com/Prod/Q...4?SSAID=198698
http://www.tools4flooring.com/md-491...er-p-1083.html
Old 04-13-2010, 06:33 AM
CarveOne is on a distinguished road
They should work ok but it depends on how much flexing you can tolerate for what you intend to make with them. They cannot be made into fully supported CNC rails.
CarveOne
CarveOne
Resistance is not futile. It is voltage divided by current (R=V/I).
Old 04-13-2010, 03:57 PM
packrat is on a distinguished road
Why would these be any worse than, black pipe and skate bearings?
cary
Old 04-13-2010, 04:55 PM
eloid is on a distinguished road
the bigges issue with them , for long spans there" unsupported rail",
add stepper "motor torque", " spindle force" and "cutting forces" excelerations ramps up and down speeds... you may find they work.... but they "will flex" ... so you must decide if you can live with that?
Old 04-13-2010, 05:55 PM
cary
I didn't say that they would be worse, nor was I trying to imply that. Just be aware of the flexing issue is all I was pointing out.
The linear bearing slides are generally much better than black iron pipe and skate bearings. These tile cutter shafts are supported at each end only, therefore they will flex, and the amount of flex may or may not be of concern to you depending on what you want to use them for. The linear bearings on these shafts do not allow for fully supporting the shafts to prevent the flexing issues.
Though people use unsupported shafts for many successful builds in these and other forums, it is not the best mechanical method to use. This is the only issue that I saw with these shafts.
CarveOne
CarveOne
Old 04-13-2010, 06:50 PM
Didn't mean to cause trouble, just wondered why no one seems to question the pipe and skate bearings.
cary
Old 04-13-2010, 07:00 PM
The underside of gas/ cold rolled pipes can be supported via the skate bearing design, the bearing on most tile cutter use 360 degree linear bearing, any support under the pipe would limit the travel with this type of linear bearing. Thus your limited .... with unsupported rail system with flex.
Old 04-13-2010, 09:59 PM
I actually thought about the tile cutter while looking for a easy, ready-made Y-axis,
for a small CNC with a small span for PCB and other small engraving.
Old 04-14-2010, 06:24 AM
cary
Black pipe has its issues as well, but they are cheap, relatively stiff, and the bearings can be arranged in a configuration that allows for fully supporting the pipe. The surface texture of the pipe can be smoothed by a thorough sanding. Longer, larger diameter pipes can be had for the cost of one typical tile cutter.
If you want to build a small 3 axis engraving machine with the tile cutter rails you will need two tile cutters to get enough rails. Otherwise, the tile cutter rails should work fine.
quadtech's idea of using the tile cutter rails for a Z axis sounds like a good use for them.
CarveOne
CarveOne
Linear rail & slides or "V" bearing & track CNCCajun Linear and Rotary Motion 4 05-07-2009 02:45 AM
UHMW vs Delrin vs HDPE rail slides Rance DIY-CNC Router Table Machines 15 01-03-2009 03:16 PM
Need Help!- cnc rail DIY, ideas?, any intersting project on cnc rails / Linear Slides? sadik007 Open Source CNC Machine Designs 0 07-23-2008 04:31 PM
A good article on round bearings (bushings) versus square rail slides guru_florida Linear and Rotary Motion 1 11-19-2007 07:19 PM
Linear Slides v/s rail slides bryanrabb DIY-CNC Router Table Machines 4 03-27-2006 08:45 PM
