Old 04-08-2010, 09:04 AM
tskguy is on a distinguished road
X and Y axis differ in motor tuning???
Hi all,
I am a newbie DIY CNC'er and have been lurking here from a month or so. I just finished building an MDF desktop router. I used acme 16tpi lead screws with delrin nuts. The issue I'm having has to do with motor tuning. I did the math to calculate the steps per unit in Mach 3 and came up with 2015.74 steps per unit.
Here is how I did it. I have 1.8 degree steppers so 200 steps per rev. I have 16th micro stepping board so I get 3200 steps per rev. A 16 turn per inch converted to mm is 16 divided by 25.4 is .6299 revs per unit. Then I multiplied 3200 X .6299 to reach 2015.748.
Is that right??? So here is what I see on the machine. I did some test and noticed things are a little off. So I dug out the dial indicator and used mach3's calibration tool. First off according to the calibration the X axis was closer to 1951 steps per unit. The Z was the same number. But the Y axis is set to closer to 2200 in order to get an accurate 1mm. Part of me is wondering if the cheap screws I bought off ebay are to blame. Or maybe the cheap controller board I bought off ebay is to blame! Or should I just leave well enough alone?
Thanks for reading!!
Old 04-08-2010, 09:47 AM
jalessi's Avatar
jalessi is on a distinguished road
Post
Tskguy,
Mach3 has a built in calibration utility.
Watch the video provided by Hoss.
YouTube- Improved Mach 3 Axis Calibration
Have a most awesome day,
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Old 04-08-2010, 10:11 AM
Thanks for the video....I actually used his quick and dirty method to come up with what I'm using now. I guess my ultimate question is why my x and y axis are so different? I am using the same screws for both axis. I suppose I shouldn't worry to much as long as its accurate. I plan on testing tonight by drilling a grid of 1mm spaced holes to verify that they are traveling the same distance.
Do think my math is good?
Eric
Old 04-08-2010, 10:39 AM
ger21's Avatar
The screws must be a different pitch. Maybe your Y is 18 tpi?
Old 04-08-2010, 10:42 AM
Maybe your right? I shouldn't worry as long as its calibrated in mach3 correctly thats all that really matters.
Thanks for the help guys! I will post a video of my little machine soon!
Eric
Old 04-09-2010, 01:56 AM
lunchtrayrider is on a distinguished road
measure over a variety of distances? maybe backlash or machine flexing?
help with motor tuning kish89 Stepper Motors and Drives 7 01-01-2010 02:34 PM
MOTOR TUNING corneliusbrown Mach Software (ArtSoft software) 3 06-10-2009 10:26 PM
New Machine Build- Mach3 , Config, Motor Tuning problem ( FILM OF MOTOR) MDF_Markazi Mach Software (ArtSoft software) 7 04-30-2009 02:15 AM
Need Help!- Help with motor tuning harrisam DynaCNC 8 05-09-2008 08:17 AM
Motor Tuning Smitty911 Gecko Drives 6 10-16-2007 04:40 PM
