Old 04-04-2010, 01:38 PM
spoiledbrat is on a distinguished road
BT-30 tool grippers for ATC system
This will really be 3 questions.
Does anyone know where I can purchase tool grips (for BT-30 toolholders) at a reasonable price? I have found some HSK ones for $50 on ebay, but nothing for BT-30.
The next question is: What would be the best plastic to use if I was to machine them myself? I can machine a slot in the bottom for a spring if necessary. I am willing to spend more to get the best material. I hope to machine them on my old CNC router (porter cable router). If not able, I do have access to a milling machine.
Third question is this: If I can produce the aluminum molds myself, what kind of cost will I be looking at to have them injection molded? It would be a limited run, maybe 50 total. I would like to embed the springs into the mold before the plastic is injected.
Would these parts be better machined, or molded?
Thank you in advance for your help.
Rob
Old 04-04-2010, 05:02 PM
elmerfud is on a distinguished road
Hi rob,
I'm designing a 6 tool carousel for my drill mill with Bt30, at my work we have a deckel maho with a bt40 carousel and the tools are retained with a simple sandwich of steel plates. No fancy machining, simply the lower two plates hold the tool and locate the key way, the upper plate is spring steel and bent to a profile that releases the tool as the carousel strikes the spindle face.
Old 04-04-2010, 06:12 PM
Elmerfud,
Do you have a picture of that wonderful contraption? I would love to see how it locates the key way.
Thanks,
Rob
Old 04-04-2010, 08:23 PM
mactec54 is on a distinguished road
Hi spoiledbrat
For 50 pieces you would be better machining them, nylon 6/6 would be normal if you want the best ultem 1000 would be the one to use
Mactec54
Old 04-04-2010, 09:45 PM
Mactec,
If a superior part is delivered using injection molding, I would prefer that. I was wondering what the cost of injection molding would be if I provided the aluminum molds myself. I can machine aluminum very slowly with my current machine.
Rob
Old 04-05-2010, 05:43 PM
spoiledbrat
In what way do you think you could get a superior part by injection molding them, I do molding & machining, Molding is only superior for hard to machine parts & when you need more than a 100 plus pieces
Mactec54
Old 04-05-2010, 05:57 PM
I guess I was mainly referring to the plastic properties desired for a part like this. (fatigue, memory, etc)
I have no experience machining plastic, and I am not sure what kind of success I would have using the porter cable router (lol)
I dont really have a finalized design yet, either.
Rob
Old 04-05-2010, 11:55 PM
vishnu is on a distinguished road
Rob,
I would be really happy to lend you a hand. I am happy to see elmer is designing 6 tool carousel. I think we can manufacture Nylon parts by injection moulding not an issue, do you have any designs finalised so we can work on them.
Tool Data Management System Kennebec General Business Practices and Pricing 11 07-28-2010 12:49 PM
New In Process Tool Measurement System kcoste Product Announcements & Manufacturer News 0 10-08-2009 11:59 PM
Tormach CNC Tool System Martin Long Tormach PCNC 6 10-08-2008 09:13 AM
System variable for tool in ready position Dana099 Mazak, Mitsubishi, Mazatrol 5 07-20-2007 03:30 PM
Quick change tool system (milling) mark c General Metal Working Machines 3 02-17-2005 06:50 AM
