Old 04-01-2010, 07:34 PM
crash5050 is on a distinguished road
Fineline Automation 2x4 Rack and Pinion build
I am building a FineLine Automation 2x4 Rack and Pinion Router. This build may take some time, I thought I would document my build for posterity.
First off, Let me give credit where credit is due. Nate has endured my relentless emails, and newbie questions, always responding with the information I requested, and never once called me a dumb A**. Nate is great. Ha, that rhymed, ok I digress.
1st thing I decided to do was build the Linear Motion Carriages, as they looked pretty easy to assemble. In all there are 8 carriages, 4 extended carriages, 2 regular sized carriages without tapped mounting holes and 2 with tapped holes for mounting on the Z axis plate. The main things you have to worry about when assembling the carriages is to watch which side you put the bolts in. Like a dummy, I put them in the wrong side and had to take them all out and redo them. The screw heads go on the side without the slotted hole, yeah pretty obvious now. I then felt confident enough to attach the 2 linear carriages to the Z axis plate, that took a little ciphering on my part, but in the end it went together perfectly.
More later and pics will follow (Digital Camer has dead Batteries)
Crash5050
Old 04-02-2010, 04:36 PM
bvz bvz is offline
bvz is on a distinguished road
Go get some batteries! Like now!
I'm very interested in following your build. I am also planning a 2x4 from FineLine as soon as I can secure the funds. Actually, I'd like to do a 3x6 from them.
Looking forward to seeing your progress.
Old 04-03-2010, 12:28 PM
Pictures?
Ok, my photography skills are somewhat to be desired, and my carea is older than I am, so here goes.
ID:	104418   Click image for larger version
ID:	104419   Click image for larger version
ID:	104420   Click image for larger version
ID:	104422   Click image for larger version
ID:	104423   Click image for larger version
ID:	104424   Click image for larger version
Old 04-03-2010, 01:29 PM
Den76 is on a distinguished road
I'm building same router. Can you tell me how fixed pinion to shaft?
Old 04-03-2010, 02:25 PM
Pinion to shaft?
Not quite sure what you are wanting here, the pinion gear has a 1 inch shoulder bolt, with a precision spacer, then a high collar lock nut. That screws directly into the mounting bracket.
David
Old 04-03-2010, 02:54 PM
Thank you
Old 04-07-2010, 07:34 PM
bvz bvz is offline
Looking like you are off to a good start! Keep the updates rolling as you can!
Old 08-16-2010, 09:51 PM
As sands through the hourglass
Well, I have been constantly building and rebuilding my machine. I have dyslexia, and it does make for some hard times when assembling things. But here it it, in all of it's glory. All I have left to do is bolt down the table, spoilerboards and the rockler rails. I have some pictures on the laptop, forgot to move them.
WIll Post in a second
David
Old 08-16-2010, 10:00 PM
Pics, As promised
Here they are.
Old 08-17-2010, 12:35 PM
Woodbutcher-59's Avatar
Woodbutcher-59 is on a distinguished road
Can't see them...
Awww. now your just being a tease....
Jeff
  #11   Ban this user!
Old 08-20-2010, 06:52 PM
Pics obviously did not post
will try again
  #12   Ban this user!
Old 08-20-2010, 07:02 PM
I had a vision
No, not one of those Jerry Garcia visions, but a vision in my head as to how I wanted my router to look, well my vision is now a reality. I never like anything I do, but fellas, I like this.
ID:	113126   Click image for larger version
ID:	113127   Click image for larger version
ID:	113128   Click image for larger version
rack and rack & pinion with off the self planetary gearbox eloid DIY-CNC Router Table Machines 4 12-06-2009 08:54 AM
Build For Speed with Rack and Pinion Mcyoda Linear and Rotary Motion 1 08-03-2008 08:05 AM
MY 3RD BUILD/ belts vs rack and pinion jeffg Open Source CNC Machine Designs 4 07-21-2008 04:08 PM
Considering rack and pinion phantomcow2 DIY-CNC Router Table Machines 12 03-12-2006 04:05 PM
calculatiing pinion size for rack and pinion setup Apples DIY-CNC Router Table Machines 3 05-18-2004 09:36 PM
