Old 04-01-2010, 09:57 AM
techguyav is on a distinguished road
ebay 3-axis TB6560 curiosity
I have recently modified a Hermes 5000 engraving machine with a dremel head and 3-axis TB6560 driver board. This is my first machine and I relied heavily on this forum in modifying it. I wanted to share my experience with the ebay driver and see if anyone has an explanation for a curiosity I found.
As several people have already experienced, the driver is not capable of the 36V that is advertised. I took others' advice and I'm only running it on a 24V, 10A, high-quality power supply. I'm not sure of the stepper brand on the Hermes, but they are 2.8A steppers. At 24V they're only warm and have enough power that I can't stop them by hand, good enough for my purposes.
At full step or 1/2 microstep, it makes the steppers scream and shake like the machine is coming apart. We had particularly bad shake at 8ipm. At 1/8 microstep they're quiet and smooth.
I have the buffer setting on fast. I tried the other settings and couldn't tell any difference. Maybe someone can enlighten me on what that does.
I started with current on 100%, but was having a "popping" noise coming from 2 axes and missed steps. I thought it was a mechanical issue, but just flipped the current switches to 75% on a whim and the popping stopped. Now all 3 axes are smooth as can be, quiet, and don't miss a step. Does anyone have an explanation for this?
Old 10-23-2010, 09:07 PM
gothdragon is on a distinguished road
Smile that board sucks lol
i am haveing bad problems with it so don't feel bad at lest you got your's working lol
mine is odd i can't get my y axle to work it make's sound and shack's the table thot it was the motor but i switched the cable's to x and the motor was fine
now i thank im going to buy a nothere board from somewhere els unless i can figer this out
time do's not matter stoping it do's if you can stop time for one hour thin that hour would be forever
Old 10-23-2010, 09:33 PM
Sounds to me like you have the y-axis stepper mis-wired.
Old 10-24-2010, 04:28 AM
leaveme is on a distinguished road
visit following thread. you have answer there.
How I fixed my Chinese TB6560 controller (updated) - CNCzone.com-The Largest Machinist Community on the net!
eBay TB6560 Stepper Motor Driver Boards Mad Professor Stepper Motors and Drives 128 08-31-2011 05:18 AM
TB6560 3-axis driver from ebay kish89 Stepper Motors and Drives 10 06-30-2011 07:10 PM
need help with 3 AXIS (TB6560) CNC DRIVER BOARD Jason Miller General Electronics Discussion 34 01-06-2011 12:25 PM
4 Axis TB6560 (compatable) Zygoat Stepper Motors and Drives 3 03-01-2010 02:51 AM
TB6560 3-axis driver manual control kish89 Stepper Motors and Drives 4 12-08-2009 03:19 PM
