Old 03-30-2010, 01:44 PM
madtownrob is on a distinguished road
R&P drive "canting" on the rack
I just got my X gantry beam completed and noticed when the X/Z is moving towards the stepper ( I mean in a direction towards the mounting bolt through the Drive to the carriage) it was quieter. When I move the axis away from the stepper it was much noisier and I see a small cant of the CNCRouterparts drive away from the rack. It now doesn't fully engage the rack or should I say it doesn't engage the rack squarely since it has a small twist. The shoulder bolt appears to have a little too much play in it and allows the pinion end of the drive to pull away from the rack when traveling towards the pinion.
Has anyone else heard/witnessed/observed this?
Thanks guys....
Tags
r&p cncrouterparts.com
Need Help!- "motor steps per resolution" and "driver microstepping" settings margni74 LinuxCNC (formerly EMC2) 9 10-24-2009 02:33 AM
"J" head type "millport"(tiwan,1980) clutch marksbug Bridgeport and Hardinge Mills 1 08-17-2009 10:48 AM
"Astrosyn Miniangle Stepper" Power Drive hferraz Stepper Motors and Drives 0 10-31-2007 03:27 PM
V2XT error message "DRIVE FAULT detected (0,z,y,x) check log" rfdoyle Bridgeport and Hardinge Mills 4 10-08-2007 03:35 PM
"IRMCS2011" AC servo drive design platform / from International Rectifier Chivo Servo Motors and Drives 4 05-17-2006 05:19 AM
