Old 05-02-2005, 05:38 PM
pyrojon is on a distinguished road
Cutting Boards
I picked up a nylon cutting board today to see how it cut and machined, egads does it cut like crap. It melts and binds up like I have never seen before.
This material is used pretty heavily from what I can tell, how do you guys machine it? Can anyone give me any clues that would make the job easier?
Jon
Old 05-02-2005, 06:36 PM
pen25 is on a distinguished road
slow your speed. slow your feed rate.
Old 05-02-2005, 07:07 PM
ger21's Avatar
What are you cutting it with? Usually melting is caused by feeding too slow.
Old 05-02-2005, 08:18 PM
Just trying to square it on my table saw.
As I cut it melts and "puddles" behind the blade, creating these gobs of molten plastic that stick to the board and really make a mess of things.
I tried the band saw and it cuts better but I still get some melting, unfortunatly the band saw isn't really the best tool when you are trying to get straight cuts.
Old 05-02-2005, 09:44 PM
Marc is on a distinguished road
What I do is put masking tape on both side of the plastic material I want to cut and it works like a charm, try it
Marc..
Old 05-02-2005, 10:20 PM
chuckknigh's Avatar
Gold Member
chuckknigh is on a distinguished road
I cut mine on my bandsaw, and it cut effortlessly. Of course, the blade has so little thermal mass, and such a huge surface area that it wouldn't build up heat!
-- Chuck Knight
Old 05-02-2005, 11:31 PM
i thought melting ment spindle or feedrate was too fast and not balanced. I know you want to cut it faster speeds and slower spindle isnt it? I am a noob so i am not 100% sure.
Old 05-03-2005, 06:48 AM
LeeWay's Avatar
LeeWay is on a distinguished road
I think the main problem is the type of cutting board material. The cheap boards are real bad about melting. There is some nicer cutting board material that is sold at US Plastics called Sanatec. This is some very nice stuff. It comes in different colors and is 1/2" thick. Mills just like true UHMW and costs less. Great stuff to work with and its very slick and ridgid as well.
Lee
musicmkr is on a distinguished road
I don't know what you're cutting with, but try something with fewer cutting surfaces. Something like a one or two flute end mill, or a narrow wood router bit should work well. Make shallower cuts and with your spindle set to a slower speed setting. Don't be afraid to add a few Z axis "pull outs" into your G-code to give the tool a chance to cool off between operations. As always a little liquid for coolant will help as well.
Old 05-03-2005, 06:54 AM
ger21's Avatar
Make a sliding cutoff sled for your table saw, so you can cut faster safely. And maybe try making light cuts and raising the blade a little each time.
  #11   Ban this user!
Old 05-03-2005, 07:28 AM
Thanks for all the advice. I am sure it will be helpfull.
As for the cutting boards, I recall that the plan calls for 3/4" adjustment blocks, are there 3/4" cutting boards out there somewhere that I havn't found yet?
Thanks again
Jon
Old 05-03-2005, 10:17 AM
joecnc2006's Avatar
www.joescnc.com
joecnc2006 is on a distinguished road
I was able to cut it with not problem on CNC here is a link to the picture.
Slow down spindle, and feed rate slightly.
http://cnczone.com/forums/showthread...7&page=2&pp=10
Joe
Having trouble cutting aluminum sheet fastturbovet General Metalwork Discussion 40 06-14-2005 10:33 PM
help with boards mocnc General Electronics Discussion 15 02-17-2005 08:18 PM
CNC router deflection calcs and cutting loads? Linus DIY-CNC Router Table Machines 1 09-10-2004 10:08 AM
question about 2 X 2axis boards Stevie General Electronics Discussion 5 03-14-2004 06:39 PM
Do you account for climb cutting in G code? fyffe555 DIY-CNC Router Table Machines 12 11-06-2003 07:21 PM
