Hi everyone. I'm new to this business. And I need your advice. Do you think this is http://cgi.ebay.com/4-AXIS-CNC-Route...item3cab696315 a good choice or not? And if not, what would you advise for me. I build a 3 axis machin, they dont have 3 axis. That why i look 4 . My budget is around 300 for all electrical parts. Thank you very much. |
| flatis, In order for others to help you in your electronics selection, more information about your machine is needed. 1) Size/work envelope of your machine 2) weight of Gantry/spindle assembly 2) Linear rails/glides/ you are using 3) Spec's for linear drive: size/pitch of acme/ballscrew, R & P/Timing belt gear reduction 4) Material to be cut/DOC, cutting speeds, rapid speeds This is some of the additional information needed. The more specific the information, the better the advise. I can not answer your question. ![]() Others will be able to help, IF you provide more inormation about your machine. Pictures speak a 1000 words! Good luck with your build. Randy,
__________________ I may not be good.... But I am S L O W!! |
| Hello thank you very much for your response and advice. I will try to write everything correctly. And I hope that I will get help. 1) 48"x24"x4" 2) 3.3 pounds 3) Metal corner with bearings 4) Treaded rod 1/2-13 TPI 5)I still do not know. But mostly I will use when building a home cockpit for panels and instruments. |
are you sure only 3.3 lbs. that seems too small for a machine that is 48" long. maybe 33 lbs? and that would still be lite. |
| Hi out their I hope I'am in the right place to find out about routers!! The problem I'am having is I just aquired a cnc router 20" X 18" , It has a FET3 board on it I need some or a lot of information on how to run the software to have these motors running , or even to joge them ! Any help please keep it simple I'am new at this !! Thanks |
| I'm sorry this is only 3.3 wt router. The whole structure weight, I still do not know. |
| Hi can anyone tell me what sofrware I should use to run a router that has 3 motors ,23D-6204H 4.3 VDC 1.8 A/O I have a FET3 board I think I have the wires hooked up right ! I have a cherokee 150 watt switching DC power supply, hooked up , I have the parell port hooked up to my computer !! Now hears my problem, What do I do now ! All the software that came with the router were lost about 6 years ago, I've seen the router run! but not with this setup! OK what do I do now ! any one THANKS router size is 18"X 20" Any information on how to go from my computer to the motors and run or jogg them, I'am lost thanks for any help |
| please tell me what is best stepper motor for my cnc router | ramysarwat | Stepper Motors and Drives | 6 | 02-19-2012 08:22 PM |
| Need a complete 3-Axis CNC Router plans | ezland00 | DIY-CNC Router Table Machines | 14 | 03-31-2010 11:06 PM |
| Newbie- Stepper motor size for X3 mill | WindyMiller | Benchtop Machines | 102 | 02-14-2009 05:29 PM |
| How can I coupling a stepper motor axis directly to other axis? | meknik2001 | Stepper Motors and Drives | 4 | 05-08-2008 01:54 PM |
| Z axis stepper motor | phidab | Syil Products | 4 | 04-10-2008 07:12 PM |
