| Came across this while searching for Micro PIC's, looks like Hyperterminal is used to output a plotter file to a PIC. I though it might be of interest to someone. http://cstep.luberth.com/PStep.html Al.
| This is an attempt to create a serial stepper driver. This guy created a program that breaks down a hpgl file into commands that are sent to the pic which in turn creates a PWM signal for the steppers. This way you are not limited by the max troughput of the parallel port. EJK
__________________ What goes down, should come up. |
| THK Slide pack FBW? Cheaper linear system? | InspirationTool | Linear and Rotary Motion | 1 | 05-25-2005 05:21 PM |
| Ametek | guitars | Servo Motors and Drives | 12 | 04-21-2005 08:12 AM |
| Wire cutting big faceted shapes | terraswarm | CNC Wire Foam Cutter Machines | 5 | 02-10-2005 04:53 PM |
| Looking for 3 tires for an old band saw. | trilect | WoodWorking | 8 | 01-24-2005 11:20 PM |
| Cheaper alternatives to SolidWorks? | dbassett74 | General CAM Discussion | 4 | 10-14-2004 01:14 PM |
