Old 03-28-2010, 11:22 PM
rodjava is on a distinguished road
Can you please identify this type of lead screw?
Could somebody please tell me the type of screw this is? Just the basics would be fine.
Thank you in advance.
Rod
Old 03-29-2010, 03:43 AM
Jason3's Avatar
Jason3 is on a distinguished road
Looks like a 2 start ground ball screw, perhaps a Star or Rexroth?
Regards,
Jason
Old 03-29-2010, 05:27 AM
brihoo2k is on a distinguished road
It looks to me to be a single start ball screw.
Is the voice in my head bothering you?
Old 03-29-2010, 07:06 AM
SORCHEROR is on a distinguished road
its a rolled single start ball screw
Old 03-29-2010, 09:00 AM
Thank you to everybody that relied so far. I looked up in Wikipedia the difference between single and double start :
Single-start means that there is only one "ridge" wrapped around the cylinder of the screw's body. Each time that the screw's body rotates one turn (360°), it has advanced axially by the width of one ridge. "Double-start" means that there are two "ridges" wrapped around the cylinder of the screw's body. Each time that the screw's body rotates one turn (360°), it has advanced axially by the width of two ridges
I'm not quite sure from my picture how many ridges are shown.
Again, thank you all in advance for your help.
Rod
Old 03-29-2010, 09:57 AM
mactec54 is on a distinguished road
Hi rodjava
No you can not tell how many start that screw is by the photo, most ballscrews only come single start, If you get a photo of the end of the screw you can see right away if it is a 2 start or not, the screw in the photo does not look in to good a shape as well,email me if you need more help with this
Mactec54
Old 03-29-2010, 10:02 AM
andyb4 is on a distinguished road
It is a single start. If you draw a line perpendicular to the axis of the thread, say from the groove in the bottom of the thread, it will be half way between the groove you can see coming down from the top, and the next one. If it were a two start thread, the line would intersect with the groove at the top side of the picture. Each "thread" is every other crest.
Old 03-29-2010, 10:12 AM
Thanks again everybody for your help.
I will call it a single start ball screw.
We can end the thread now, unless somebody has an opposing view.
Best regards,
Rod
San Francisco
Identify spring type. John Welden Mechanical Calculations/Engineering Design 3 05-21-2009 10:46 PM
How do you mount a lead screw/lead nut? jbluetooth DIY-CNC Router Table Machines 2 12-01-2008 04:10 PM
Belt vrs. Ball Screw vrs. Lead Screw stevesplanes Linear and Rotary Motion 7 01-09-2006 11:23 AM
New technology.... old debate.....ball screw vs lead screw trubleshtr Linear and Rotary Motion 1 08-15-2005 08:42 PM
Ball Screw or Lead Screw? Which is Better? ljoe1969 DIY-CNC Router Table Machines 4 07-28-2004 08:49 AM
