Old 03-26-2010, 01:17 PM
vais is on a distinguished road
spindles
hey guys,
im realy new to the mechanics world and i was wondering
what kind of spindle ill need for metal milling cnc (stuff like aluminuim - stainless steel - brass etc.)
what speeds it will need for example milling with 2mm dia?
and how much power the spindle need to be so it wouldn't be to coasty and suit small cnc mill?
and what cost sould i look for?
tnx =]
Old 03-26-2010, 09:00 PM
Jesse B's Avatar
Jesse B is on a distinguished road
How big is your machine? What materials are you planning on machining (specifically). There are many different types and sizes of spindles. Also, how much would you LIKE to spend on it? We can let you know if your budget is realistic or not.
Old 03-27-2010, 03:52 AM
i already answered these questions
budjet as low as posible
matirials metals like aluminuim - stainless steel - brass (im not familiar with the specific models of each of them as i sayd im new to this world) and i want to mill small stuff - so it should be able to handle 2mm bits on those matirials
hope this answers your questions
HF spindles endgrainguy General Electronics Discussion 0 09-29-2008 01:00 PM
Air spindles sizmo Toolgrinding & Toolgrinding Machines 1 12-16-2007 08:06 PM
What spindles to use woodbutcher Mechanical Calculations/Engineering Design 0 11-05-2006 08:44 AM
air/oil spindles Shizzlemah Fadal 2 06-08-2006 09:41 AM
