Hello all! I have a custom built CNC machine and I was cutting a thin piece of material only cutting .010" I noticed that part way through my program the cuts were getting deeper. Well after a long process of elimination i measured the z axis, ran the program with the router turned off and no tool in the collet. When the program was finished and the machine returned to home, the z axis was of by .300" I check a couple times and the distance was consistent. I am using Mach3 and This is really driving me crazy can anyone point me in the right direction? |
| This happened to me a few weeks ago. My problem ended up being a loose encoder wire ate the motor. Another possibility is a loose encoder, able to rotate freely on the shaft (when it feels like it )If you have steppers, this does not apply. Cheers! ' Rob |
| Grinding and unexpected axis movement if rapiding 2 axis | DarkSabre | Taig Mills & Lathes | 4 | 03-25-2010 11:37 PM |
| New Machine Build- post for 2 axis ez trak versus 3 axis ez vision | tooolman | G-Code Programing | 0 | 11-28-2008 03:33 PM |
| Compare Catia and MCX2 for multi axis lathe/4 axis mill | bob1112 | General CAM Discussion | 0 | 10-10-2008 07:15 PM |
| How can I coupling a stepper motor axis directly to other axis? | meknik2001 | Stepper Motors and Drives | 4 | 05-08-2008 01:54 PM |
| New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter | the__extreme | CNC Wood Router Project Log | 3 | 02-26-2007 02:58 PM |
