Help, please. I like the idea of keeping the electrical connections that go to the control box easy to disconnect. So the motor cables and the DB25 cable fit that bill. But I have the e-stop hooked in through a regular 110v male/female plug - kinda crude but effective. Now I am about to add a probe wire for use in zeroing the axis. And I would like advice about the best kind of electrical connector to use. I have considered banana plugs, and RCA plugs, and even a bolt and a nut through a piece of delrin. What does everyone else use? Last edited by zeeway; 03-26-2010 at 03:11 PM. |
| If you can afford the cost go with circular plastic connectors. Also know as canon plugs or military style connectors. They are keyed and are made for repeatable positive contact. They are made for industrial use and keep dirt and grime out. What’s an extra 3 bucks for the connector compared to the lost revenue of bad part? Kris |
| http://www.mouser.com/catalog/629/1037.pdf The MS, Cannon or Military style are metal and are quite a bit more, cost wise. Al.
__________________ CNC, Mechatronics Integration and Machine Design. “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. Last edited by Al_The_Man; 03-25-2010 at 10:15 AM. |
| i used these on my build - pretty much what is used on hydraulic / air valve connections ![]() ![]() You can get them with 3 or 4 pins. I've also used 'weatherpack' connectors for my servo motors, and they are available in a number of pin configurations i hate how connectors & cabling adds so much cost, but it makes it nice! |
| Hi to connect my steppers i used these http://uk.rs-online.com/web/search/s...duct&R=2976555 5 pin plugs so i had 4 for the stepper signals and then 1 for the earth from the motor to my common ground back at the box. |
| Newbie- 4 Conductor Connectors | Praymond1209 | Stepper Motors and Drives | 1 | 02-17-2010 11:21 PM |
| New Machine Build- Connectors | LaserImage | General Electronics Discussion | 6 | 07-10-2008 12:53 PM |
| PowerMax II connectors | Bryanpl | Stepper Motors and Drives | 16 | 06-23-2007 11:51 AM |
| Lovejoy connectors? | OCNC | DIY-CNC Router Table Machines | 3 | 08-18-2006 09:10 AM |
| DB-25 Connectors | Nmbmxer | General Electronics Discussion | 3 | 10-16-2005 07:05 PM |
