Old 03-23-2010, 08:10 AM
w102acd is on a distinguished road
Colt - Rotozip - Dremel
All,
I am sure this is out there already, but just wanted it reiterated.
I have used a Rotozip as the spindle for a self designed and built 3 axis CNC. As stated multiple other places around the zone, the runout is terrible at best!!! So I started looking for fixes and came up with none. I noticed the nice folks over at precisebits.com sell new collets and nuts for various routers and trim routers. So I emailed them and they mentioned that the low quality parts used in the Rotozip make it not practical to fit with a precision collet and nut. And if you want a more precision tool use a Colt with the replacement collet and nut.
I read this multiple places before going against the recommendation of the zone (bad idea!!) and bought a Rotozip anyway. So I felt it necessary to put it out there bluntly.
The Colt is comparable to the cost of the Rotozip or Dremel. The Colt will hold a tool truer using the stock collets and nuts. If this still is not true enough you can easily upgrade to a very precise collet and nut. The Rotozip or Dremel do not have this upgrade option (that I have found).
Bottom Line: If there is any chance the you will need precise tool holding, buy a Colt instead of a Rotozip or Dremel. Or (like me) you will find this out the hard way and end up buying a Rotozip and a Colt.
Thanks,
w102acd
Old 03-23-2010, 01:42 PM
DIYaholic's Avatar
DIYaholic is on a distinguished road
Silver Lining!
w102acd,
On the bright side, you now have a rotozip for other uses. You can always use it to complete some of your "Honey Dew" list and other DIY projects.
Randy,
I may not be good....
But I am S L O W!!
Old 03-25-2010, 08:49 AM
All,
I now have an interesting question:
I have tried to machine aluminum with my machine as is and it does not go too well. Could this be because of the runout on the Rotozip is so terrible??? I have read other places that runout on the spindle will kill tools and surface finish.
Just curious if I replace my spindle, will I have a better chance at aluminum???
Also, if I replace my spindle I will probably build a proper aluminum mount for it. Right now I have the rotozip housed in an MDF mount. Machine rigidity is probably an issue with mine. Unfortunately, I can 't afford to make an all aluminum structure.
Thanks,
w102acd
Old 03-25-2010, 01:41 PM
revwarguy's Avatar
revwarguy is on a distinguished road
I can't claim much experience with aluminum on my cnc, but I do know that to do aluminum, you need to lower the spindle speed to prevent melting, and that ups the need for more power from the spindle.
I do have experience with using a Colt, and I am a happy camper. There are two kinds - one that has variable speed (with you can find for about $70, and one that provides variable speed for 90-100 bucks. They both have a "slow start" feature that prevents them from be controlled by an external speed controller, so getting the manual but variable speed version is a good idea.
Old 03-26-2010, 12:11 AM
JoeSixPack74's Avatar
JoeSixPack74 is on a distinguished road
Hi, I have been lurking around this site for a few months now and this my first post so I hope this does not seem like a dumb question. But this 'Colt', are we talking about a Bosch Colt palm router? I am, just like alot of people building a table top cnc machine and was going to go the rotozip way but am interested in this colt.
Brian
Old 03-26-2010, 12:45 AM
Aryantes is on a distinguished road
Yes the Colt would be the Bosch Colt.
Another popular one, is the Hitachi M12VC
Amazon.com: Hitachi M12VC 2-1/4-Horsepower Variable Speed Router: Home Improvement Amazon.com: Hitachi M12VC 2-1/4-Horsepower Variable Speed Router: Home Improvement
Pretty cheap, more HP, variable speed. I think a lot of people on this forum use it.
Definitely invest in a real router instead of a dremel or rotozip though, as mentioned.
Old 03-26-2010, 02:50 AM
Zygoat's Avatar
Zygoat is on a distinguished road
my personal recommendation.
very similar specs to the hitachi.
http://www.sears.com/shc/s/p_10153_12605_00917542000P
$30 cheaper. you can pick it up at sears. with a good warranty.
its what i bought.
Question for Jim Colt plain ol Bill CNC Plasma and Waterjet Machines 2 10-03-2009 07:09 AM
Problem- Kiwa 510 colt davidtame Fanuc 0 07-10-2009 02:36 AM
Dremel vs Rotozip Techbuilder DIY-CNC Router Table Machines 11 09-30-2008 04:22 PM
TO JIM COLT DISCONNECTED CNC Plasma and Waterjet Machines 0 09-26-2008 09:38 PM
Rotozip Ursine DIY-CNC Router Table Machines 0 09-05-2005 05:05 PM
