Old 03-23-2010, 07:42 AM
danmcgee's Avatar
danmcgee is on a distinguished road
Tool Comp's DIY CNC Router Table Plans
I have been looking for a set of plamns to build a CNC Router table that I could use to cut thin aluminum on for some aircraft parts. I came accross this site by Tool Comp and they offer a set of plans and a really good build document and support for thier table. $100 here is the web site.
http://www.machinetoolcamp.com/DIY%20CNC%20Routers.htm
Before I pay for these plans is there any comments from the CNC community about weather I would be waisting my money or if these plans are good to build a solid table. Comments from someone that has built this table or one from the plans of any size would be welcome.
Thanks Dan
Old 03-23-2010, 01:01 PM
jsheerin's Avatar
jsheerin is on a distinguished road
It looks reasonable. You could design the same machine by spending the time to do the research on this forum, so essentially what you're paying for is them taking the time to do that for you. That manual does look nice from their sample. I would change a few things on the frame design, but it's nothing that is really bad - I'm sure the machine would work fine as is. The only things that bother me are that I can't see what the drive system is - screws or rack and pinion? - and they don't give very complete specs, the biggest omissions being how fast it can rapid and cut.
Old 03-23-2010, 01:30 PM
danmcgee's Avatar
I was looking at useing Roton high quality screws and getting my electronics from http://kelinginc.net/index.html I think it is a G540 system.
What would you change about the frame designe I am only buying the plans so I have a place to start. I do not have the time to do all the research here to build my own nor do I know enough about CNC to know what right would look like.
I am learning Solidworks wells and am sure I can run the CNC without problems but do not want to wasit time and money. I need a table that will have a cutting area of 4X8 and can cut .125 think aluminum and smaller. Would like to get as close to .001 persion with a tollerance of at least .005 repeatable.
Let me know what you think
Dan
Old 03-23-2010, 01:36 PM
jsheerin's Avatar
Personally I would do dual drives on the X axis and support the bed at more locations than just the ends. It looks like they are possibly driving it in the middle and have the linear rails under the table. For the gantry, where they have a top and bottom rail, I would connect those together. This would give it much higher stiffness, but it might not work with how they have laid out their drive system.
Old 03-23-2010, 01:43 PM
danmcgee's Avatar
I will support thwe table along it's entire length to make the table more sturdy. Some one else also told me to use duel screws for the X axis and also for the Y axis depending on length. I would want to move the drive system out to the sides to drive the table using the best stepper motors folks on here seguest and best screws. I only want to do this once.
If you have a great design then I am game.
Dan
Old 03-23-2010, 01:52 PM
jsheerin's Avatar
I have an okay design. Pics here:
http://ldsg.snippets.org/HORNS/images/cnc/
I'm working on a new design that corrects the issues I've had with this one. However the biggest issue for me is speed - my current router won't go as fast as I want. That's why I say it's worrisome to me that they do not spec that out. Yes, you could change it, but I imagine they have it designed with certain parts and I would be interested in what that was if I was building that router. When you start changing things, the changes have a way of rippling through the rest of the design. For example, I am switching to servo motors instead of steppers. That requires new motor controllers. They require a different (larger) power supply. They also will require a different breakout board to interface with the computer, etc.
Old 03-23-2010, 02:01 PM
danmcgee's Avatar
Well your design certianly cuts aluminum well. Your frame constrcution looks like tha same or like material the DIY one uses.
Would most likely never be cutting alum that think but cool if it could.
Dan
Old 03-23-2010, 03:37 PM
jsheerin's Avatar
Yes, mine is 80/20, and I imagine theirs is too. I bought all mine on ebay surplus.
I just cut aluminum in very thin passes - usually around 0.020" per pass at around 20-40ipm.
Old 03-24-2010, 10:14 AM
danmcgee's Avatar
Cool the skins of the aircraft are only .020 in thickness so you could cut it in one pass. Most of the airc raft is this size some is smaller.
So I am not palnning on cutting large sectuion of aluminum just some thin stuff size is the only issue or I would build a much smaller table.
Dan
Old 03-24-2010, 10:15 AM
oeffner is on a distinguished road
google Mechmate free plans, lots of support on their forum, well proven design
  #11   Ban this user!
Old 03-24-2010, 01:14 PM
danmcgee's Avatar
I have the MechMate plans but would like to stay away from the welded steel frame and the foot print of the machine is much larger. I haved also gotten some real negative feeback about excessive backlash in regards to the MechMate built per plans, however I may still decide to build that design depending on the information I get here.
Has anyone had any experiance with this DIY machine from Tool Comp. I do know they offer ready made comercial machine with a good record.
Dan
  #12   Ban this user!
Old 03-26-2010, 01:37 PM
Gerald_D is on a distinguished road
Post deleted
Last edited by Gerald_D; 03-26-2010 at 01:43 PM. Reason: Not worth going into this misconcepton of backlash again
4x8 table plans available, oldhack DIY-CNC Router Table Machines 11 08-25-2009 06:04 PM
4' X 4' TABLE PLANS 05fmtc Open Source CNC Machine Designs 6 05-23-2008 04:19 PM
table plans DUST_U CNC Plasma and Waterjet Machines 2 01-28-2008 06:05 PM
Free plans Router table Thanks, But help aircub DIY-CNC Router Table Machines 7 10-16-2005 02:14 PM
Cnc Router table Plans and ideas ljoe1969 DIY-CNC Router Table Machines 23 11-13-2003 08:12 AM
