Old 03-21-2010, 11:41 PM
ranju is on a distinguished road
Home/Limit configuration in Mach3
Many thanx to the community.
Final I built my first CNC with all the info from this site. It is still not up-to the mark but at least I built something. :-)
The details of the machine are as follow (just to give you some idea).
- 2 stepper for X-axes
- 1 stepper for y-axes
- 1 stepper for z-axes
- Separate Home switch for each axes but NO Limit switch
- L297/298 based drive controller
Now I'm fighting to configure Mach3 for my machine. Seems it is the hardest part for me! Buddy please help me, I'm having folllowing trouble -
1. Motor is humming after configured in Mach3 but they are moving with jog button
2. Configured all of the Home switches but cannot realize to configure the soft limit (as I don't have physical limit switch)
Appreciate your help.
Old 03-22-2010, 01:47 AM
metalworkz's Avatar
metalworkz is on a distinguished road
Hello ranju,
Once you have the Home switches set up correctly you do not need limit switches on the axis also. Mach3 will let you specify the travel from the Home position in both the minus and positive directions to use for the soft limits. If you know the total travel for the axis and where the Home is located you can figure how far it is to the soft limit for both the + and - directions and key those into the soft limits. You will want to provide a small buffer zone for each direction so the screw does not reach the end before stopping.
Always home each axis before using so that Mach will know where they are and your positioning should be fine.
Regards,
Regards,
Wes
Old 03-22-2010, 02:08 AM
Originally Posted by metalworkz View Post
Hello ranju,
Regards,
hello metalworkz,
thank you so much.
please guide me where to configure this soft limit (sorry, I'm a newbe).
regards
Old 03-22-2010, 02:15 AM
metalworkz's Avatar
Hello,
In Mach3 under the Config tab, in the drop down menu select Homing and Limits.
this will pop up the Motor Home/SoftLimits setup menu and if you are using a 3 axis machine you will want to key in the Soft Max and Soft Min dimensions for each axis(X,Y, and Z) You can also key in the Slow Zone so when the machines nears the soft limits is will slow down some. I hope this helps, but keep asking if you need more info. Did you set up the Home switches with the Automated setup in Mach?
Regards,
Regards,
Wes
Old 03-22-2010, 03:15 AM
metalworkz's Avatar
Good luck, I have to sign off for now. I will check back later today.
Regards,
Wes
Old 03-22-2010, 11:49 PM
metalworkz's Avatar
Hi ranju,
Were you able to get the soft limits configured OK?
Regards,
Wes
Old 03-23-2010, 12:43 AM
Sorry buddy, I couldn't test and reply soon. I worked up to a late hour in office yesterday.
I'm actually slowly-slowly getting things though still I couldn't manage to set the soft limits. I attached here some pics of my config. Hoping it will help to have your expert guidence. :-)
One thing I'm not yet getting is the SoftMax and SoftMin, I was thinging that, SoftMin is the home zone and SoftMax is the end zone. But my trial proved me wrong. Your comment please.
ID:	103486   Click image for larger version
ID:	103488   Click image for larger version
Old 03-23-2010, 01:18 AM
metalworkz's Avatar
Hi ranju,
Say you have 18" travel for an axis and you position your home switch at 9.0".
Then you have a Soft Min of -9.00 and a Soft Max or + 9.00. You need to figure the total travel and then figure how much travel to the minus and plus sides of the Home switch and then input them into the fields on the forms. Don't forget you might want to use the slow zone also to slow the axis down as it approaches the limit.
Regards,
Regards,
Wes
Old 03-24-2010, 02:48 PM
MorfiusX is on a distinguished road
ArtSoft has some tutorial videos that are helpful:
http://www.machsupport.com/videos/
There is a Homing, Limits and Offsets video that will walk you through the configuration.
Old 03-24-2010, 04:24 PM
br1 br1 is offline
br1 is on a distinguished road
Sorry, I see that Morfius suggested to go to the link under Homing, Limits and offsets. he's right it is explained best there.
boss 5 / mach3 hillbilly bob z limit home tom.jelly Bridgeport and Hardinge Mills 4 10-30-2008 02:26 PM
Mach3 for Maxnc 5 configuration wushu2266 Mach Mill 0 07-06-2008 12:12 PM
Can someone Please help me how to save my mach3 configuration as a xml file JaiTalkin Machines running Mach Software 2 06-03-2008 11:29 PM
Mach3 limit switch problem on Ref Home originator Mach Software (ArtSoft software) 1 03-13-2006 08:02 AM
Home and Limit kenlambert General Metal Working Machines 6 04-02-2004 11:00 AM
