Old 03-20-2010, 02:55 PM
ripper7777777 is on a distinguished road
Table Top Material for Garage in Humid Houston Texas
Well the long title says it all, I live in Houston Texas and my Table is in the garage.
I bought this table off of Ebay a year or so ago, it's a Masters CNC 16"x34" table.
The table surface is currently made from 3/4" plywood with two aluminum rails running the length for clamps and I'm sure support.
The plywood is beginning to or may have always been a bit warped in the center.
So I'm in need of a new table top and was looking into MDF, but I'm worried the constant changes in weather here would warp it.
So is there any plastics that would work? The machine itself is made from I believe HDPE.
Thanks for any help.
Old 03-20-2010, 03:16 PM
ger21's Avatar
If it's not supported in the center, anything will sag over time. I'd recommend 3/4" baltic birch. Thicker would be even better. And thoroughly seal all sides with several coats of polyurethane.
Old 03-20-2010, 03:42 PM
Sorry forgot to mention it's bowed up in the center, it's not sagging, but If I went MDF I plan to support it with aluminum rails.
Old 03-20-2010, 05:08 PM
Dusty Mills is on a distinguished road
For your conditions I would recommend going with phenolic. MDF while inexpensive will suffer from the same problems, if not worse in some instances then the plywood you now have. Warning, it's rather expensive, but it will remain rock solid level over time and if your work demands precision then it could be well worth it. Look for it where plastic sheet stock is sold or on eBay.
Old 03-22-2010, 07:55 PM
ghostlx's Avatar
ghostlx is on a distinguished road
some thing I am going o try is pvc at my local lowes .
the have 6"x8' flat pvc in between each sheet i am going to install t-slot pvc will not warp dew to humidity
ghostlx
http://www.pure-teck.com/home.html
Job Opening CNC Machinist needed ASAP in Houston Texas!! lonestartemps Employment Opportunity 0 04-16-2009 08:31 AM
Need experienced EnRoute designer Houston Texas jtay Employment Opportunity 2 11-26-2008 08:31 AM
New Machine Build- 49" x 97" MechMate Build in Houston Texas, USA (detailed log) dmoore CNC Wood Router Project Log 18 06-09-2008 01:34 PM
South Texas Machine Tool Show Houston fukeneh Trade Shows and Events 0 06-03-2008 10:41 AM
Houston Texas ginamc Mentors & Apprentice Locator 14 06-22-2005 03:19 AM
