Old 03-20-2010, 08:52 AM
n1k86 is on a distinguished road
Controlling Speed of Bosch 1617 via CNC
I have a Bosch 1617 spindle that I will be using for my new router, a Blurry Custom's that I just ordered with a g540 electronics setup, and I remember reading somewhere about controlling the speed remotely with Mach 3. I searched for a whie and haven't come up with it so any help would be great.
Old 03-20-2010, 09:40 AM
GaryCorlew's Avatar
GaryCorlew is on a distinguished road
Harborfreight has them:
http://www.harborfreight.com/cpi/cta...emnumber=43060
But as you turn the speed down you also loose power, I have a Milwaukee and it is the most quiet one out there at the time I bought it. It has different speeds on it with a feed back system on it so that it maintains the set speed
Old 03-20-2010, 10:36 AM
I think this is what I was talking about. It is used in conjunction with the controller on your link. Thanks for the reply.
http://www.cnc4pc.com/Store/osc/prod...roducts_id=179
Old 03-20-2010, 11:58 AM
SatanKlawz is on a distinguished road
Those machines look nice. I reverse engineered their design by looking at it and have built my own at about 1/3 their cost. I even found the same places they buy all their stuff from. Either way nice machine man.
Old 03-20-2010, 12:17 PM
Drools's Avatar
Drools is on a distinguished road
I purchased the C29 from cnc4pc.com. I tested the unit with a pot and my Porter Cable router, it works fine. I have yet to hook it up to Mach3 and let it control the spindle speed but it is on the todo list along with a pile of other things.
Old 03-22-2010, 01:15 PM
revwarguy's Avatar
revwarguy is on a distinguished road
Some of the Bosch routers (like the Colt, for sure) have a "slow start" feature that ramps the speed up when starting - if this is so, an external speed control unit (like the one referenced earlier from HF) won't work. They can also often have as an option, a speed control on the router, which also prevents external speed controllers from working.
Old 03-22-2010, 09:10 PM
The 1617 does in fact have a soft start feature. I have one for my machine and I used it a bit on another project already. It was one of the reasons I chose it anyways. I did not want a router without this feature because the torque generated on start up is enough possibly jerk the machine out of alignment. I have a milwaukee that does this that I just use as a hand tool I make sure I turn it on before it touches any surface just in case it jerks and bites in unexpectedly.
Old 03-23-2010, 06:38 PM
revwarguy's Avatar
I can positively tell you that I own a HF speed controller, and a Bosch Colt with the slow start feature, and the HF speed controller does not work with the Colt.
Old 07-15-2011, 05:02 PM
TDA TDA is offline
TDA is on a distinguished road
I know some of our customer use the Super-PID (Link) for control in Mach on the Bosch routers.
[edit] Sorry had 2 sets of threads open blurry search and current. Didn't realize I posted to a old one.
John Torrez
Think & Tinker / PreciseBits
Newbie- Controlling Router Spindle Start/Stop/Speed AntonCNC General CNC (Mill and Lathe) Control Software (NC) 10 10-17-2009 03:04 PM
Controlling servos? crash80 General Electronics Discussion 3 08-12-2009 11:50 AM
controlling spindle speed R.thayer LinuxCNC (formerly EMC2) 4 01-14-2007 11:43 PM
Help with controlling CNC! Kammo1 Stepper Motors and Drives 2 06-11-2005 02:54 PM
controlling x axis mikejkd DIY-CNC Router Table Machines 0 05-17-2005 09:19 PM
