Old 03-18-2010, 12:56 PM
mrendu43 is on a distinguished road
cnc spindle
hi ppl. i plan to make my own spindle, so if someone knows dimension of the spindle collet holder?
outside diameter, inner diameter and depth of the holle in which collet goes. please tell me.
Old 03-19-2010, 04:14 AM
H.O H.O is offline
H.O is on a distinguished road
Well, that depends on which type and size of collet you're planning to use. I'm sure there are tens of different types of collets and then each type usually comes in different sizes as well. Like ER8, ER11, ER16, ER20 etc.
Here's a .pdf with dimensions on the ER-collets, if you choose to go that route. I'm sure a little a Google search will bring up similar references for other types of collets.
Old 03-19-2010, 01:31 PM
thanks mate. you relay helped me.
This is exactly what I was looking for, i will use ER16 cullet,for it i will make a slot in my spindle.
1992 VF2 Alarm 123 spindle Spindle Drive Fault dafowfidy Haas Mills 15 05-14-2012 01:32 PM
spindle motor and spindle control dont work customcncparts Milltronics 0 10-01-2009 02:08 PM
Feed rates / spindle speeds for HF spindle yngndrw General Metal Working Machines 2 03-21-2009 10:46 AM
Sweo spindle drive? new mill dead spindle Shizzlemah Fadal 13 12-18-2008 11:11 AM
Lathe spindle bearings and spindle material mackeym Linear and Rotary Motion 1 08-11-2007 10:53 AM
