Old 03-15-2010, 11:50 AM
fernandosantos is on a distinguished road
Steper Motor vs Servo Motor
Hello,
I am about to buy a CNC table machine to work with acrylic´s, but I have a serious issue...some say that for a 1500x1000 mm (working area) servo motors are to much others say that is the best option.
Can you help me with your opinions, what i will do better?
Buying with servo motors or Steper Motors?
Thank You
Fernando Santos
Old 03-15-2010, 01:05 PM
Al_The_Man's Avatar
Just depends who you talk to, .
Most use steppers for the ease of fitting and less cost, I personally prefer servo's, whatever the size, there is no really particular deterrent to using servo's however small the system is, apart from the cost issue previously mentioned.
Servo's possibly require slightly more tuning.
They have an advantage of much higher rpm while retaining torque throughout the total rpm range.
samu's Avatar
samu is on a distinguished road
stepper lost a lot of torque at high speed but are much less expensive(motor itself and the drive too) Evrething depend at which speed you want to run and how much you want to spend on your machine. For an industrial use 10 hour per day servo must be considered but for hobby work i think it is overkill
Old 03-15-2010, 05:14 PM
how to decide?
Thank you for your opinion,
Now, other issue...
I have to decide about this two machines:
1- 1500x1000 (working area)
Servo Motors
High rigid aluminium structure
Made in Portugal (www.pronum.pt) with European components.
High precision on Z axe
Transmission: Rack/Rack (150 mm belt diameter)
Price: $ 13 300
2- 1300x1300 (working area)
Stepper Motor
Steel Structure
Made in China High precision on Z axe
Transmission: Rack/Rack (165 mm belt diameter)
Price: $ 10 750
What machine will you choose if you have to work 8 hours per day.
Fernando
Old 03-15-2010, 11:17 PM
Benonymous's Avatar
Benonymous is on a distinguished road
Another factor you may want to consider is whether you're buying DC servos or AC servos. AC servos and their associated controllers will be more expensive but AC servos do not have brushes and commutators to wear out.
Brushes can also generate electromagnetic noise.
Anyway, I chose AC servos over DC servos for the lack of brushes.
I guess for a machine that is not running constantly it may not be a big factor but if the machine is going to get commercial use for hours a day, you don't want to be fussed with changing brushes.
Old 03-16-2010, 12:56 AM
lunchtrayrider is on a distinguished road
if those are ac servos probably the one from Portugal would be my vote.
Steper motor max. RPM mb123 Stepper Motors and Drives 16 09-11-2011 04:16 AM
steper motor brain fart squid1230 Hobby Discussion 1 07-09-2009 11:22 PM
Steper Motor TO HOT!!!! PLEASE HELP Chivo Stepper Motors and Drives 6 11-10-2005 10:08 PM
Steper Motor & Driver Problem -Please Help Chivo Gecko Drives 5 08-29-2005 06:10 PM
Steper Motor & Driver Seting--- Please Help Chivo Stepper Motors and Drives 4 08-24-2005 07:15 PM
