Old 03-15-2010, 07:22 AM
Djk Djk is offline
Djk is on a distinguished road
sanyo Denki stepper motors
Can you guys help me, which is the best motor
Sanyo Denki SM2862-5255
bipolar
6A/phase
Holding torque 7 NM
Resistance 0.36 Ohm/phase
inductance 2.8 mh/phase
Sanyo Denki SM2862-5155
bipolar
4A/phase
Holding torque 7 NM
Resistance 0.83 ohm/phase
inductance 6.4 mh/phase
Is it better to have more inductance or more Amps
Old 03-15-2010, 09:51 AM
Pandinus is on a distinguished road
With a Higher inductance the current/magnetic field take longer to reach full strength.
So a lower inductance allows for a higher switching speed and therefore more usable torque at higher speeds, if that's what you want...
Between the two, not counting the Drive used, I'd guess that the -5255 would get you higher speeds and acceleration than the -5155
There are a lot of factors in motor selection... The larger the motor (physically,) the higher the rotational mass so the more power required to accelerate and decelerate just the motor... "Sometimes" a smaller motor can perform better depending on the rest of the system...
Old 03-15-2010, 09:57 AM
Djk Djk is offline
Thanks pandinus I will go for the 6A motor
Step-Syn Stepping Motors Sanyo Denki Shanghyd Stepper Motors and Drives 1 01-16-2011 11:47 AM
Need Help!- old MAE & Sanyo Denki stepper motors oliv1969 Stepper Motors and Drives 4 08-01-2009 10:00 AM
Need help with Sanyo Denki stepper vova Stepper Motors and Drives 3 05-20-2008 11:16 AM
HELP !! Sanyo Denki stepper motors ??? what are these ones ?? FPV_GTp Stepper Motors and Drives 4 03-21-2007 11:46 PM
Sanyo- Denki Step Syn motors need some help on driver for rollin_ballz1 DIY-CNC Router Table Machines 0 03-07-2006 08:21 AM
